TopRC giant P-47 Thunderbolt ARF >
Old 05-08-2022, 05:51 PM
  #151
My Feedback: (-1)
bradley's Avatar
Originally Posted by JRSmith
I plan on checking out the gear and testing it well before installing it into the airplane and if the retract units need to replaced, then I will do that before final install.
You Grandfather's life lessons are on point and very true, Life is way too short! Too many airplanes/helicopters and not enough time!
If the CAD or .stl files for the Chin Scoop are available to share, then I could print a couple more out if anybody needed one for their airplane, either in Engineering Resin or PETG. I planned on designing my own with the help of Aircorps Library documentation, once the airplane got here, but no need to reinvent the wheel if the designer of the files is willing to share. Looks like a bunch of little fun items to design and modify.
PM sent
Old 05-08-2022, 06:00 PM
  #152
My Feedback: (47)
JRSmith's Avatar
Originally Posted by bradley
PM sent
Thanks Brad, I did receive the PM and I sent your friend an email to inquire. Thanks again.
Jason
Old 05-08-2022, 06:02 PM
  #153
My Feedback: (-1)
bradley's Avatar
No Problem
Old 05-08-2022, 08:10 PM
  #154
The dummy intercooler was 3d printed by a friends son. He did a nice job on these. Built 2 units for the 2 of us in our club that have this plane.
Nice job on the Linkage. Carbon rod and 3 mm links? correct.
Thanks, they're 4-40. Only because I have a lot more SAE hardware around than metric. I installed all the stock 2mm stuff originally, but couldn't deal with the thought of screws that small on a 35+ lb plane.
Old 05-08-2022, 08:20 PM
  #155
Jason, I am interested in an intercooler if you make some. Let me know how much you would need for 1. Thanks.
Old 05-09-2022, 04:28 AM
  #156
My Feedback: (-1)
bradley's Avatar
Ah, that makes sense. I tossed my 2 mm hardware too. Overall. I have been trying to switch all from SAE to metric for a few years now. I have a large selection in my shop now. Mine is similar to yours, but in 3 mm. Its very strong in that size.
Brad
Old 05-09-2022, 05:30 AM
  #157
My Feedback: (47)
JRSmith's Avatar
I did get the CAD file and I am going to print a test part today from PETG and see how it turns out. I will post some results later today. No charge for the part. Talk soon.
Old 05-09-2022, 06:44 AM
  #158
My Feedback: (-1)
bradley's Avatar
You got the CAD file from my friend Geoff. Good to hear.
Old 05-09-2022, 06:47 AM
  #159
My Feedback: (23)
maddog-RCU's Avatar
Jason,
I would definitely want one of the chin coolers also so if you are printing them how about one for me; would gladly compensate you for shipping; material cost; or whatever.
Mike
Old 05-09-2022, 07:49 AM
  #160
My Feedback: (47)
JRSmith's Avatar
I did and it looks great, thanks for your help, I really appreciate it, I did let Geoff know that its for personal use, but I may print out a few for members here, no charge though, since its not my design. I am getting it sliced today and ready to print. I do want to confirm that the dimensions of the cowl where the top of the chin scoop attached is approximately 9"? I don't have one to compare to right now.
Originally Posted by maddog-RCU
Jason,
Mike
Hello Mike,
I am working on the settings for the chin scoop to help it print a little faster. Right now on the FDM machine, I am looking at 25 hours to print one, so these are going to take some time to print. But I am still working on slicer setting to speed it up, but still be strong. Talk soon.
Jason
Old 05-09-2022, 09:53 AM
  #161
My Feedback: (47)
JRSmith's Avatar
I was able to get the print down to nine hours. I tend to print at slower print speed, typically around 20 mm/s, that way there is virtually no finishing need for the finished part. However, the machine I am using is capable of much higher print speeds and since this part is not that complex, I increased the print speed up to 60 mm/s. This will needed to be fine-sanded, filled and painted to add final details, before installation, so the extra speed will work great. So far the print is looking good. I will send some pictures when finished, but here are a couple to start. Thanks.
Jason
Craftbot 3 with StatPro Filament drying cabinet
Top RC P-47 Chin Scoop designed by Geoff's son an printed in PETG.
Old 05-09-2022, 06:53 PM
  #162
My Feedback: (47)
JRSmith's Avatar
First Cowl/Chin Scoop is finished and it looks OK and certainly a useable part with a little sanding, filler, and primer. There where a few imperfections in the print and the edges lifted a little in the corner(s). But, I did increase the speed three times and I normally print with a raft with larger parts to help prevent lifting in the corners, but I figured that faced aft in the cowl, so not a huge deal if there was some minor lifting if there was. I could have also used a brim to help the stick in the corners. Many ways to skin a cat, so to speak.
Total weight was 6 oz, so it has some weight with the 40% infill. Might try and cut that down, but I am sure this airplane will need some nose weight. I thought about modifying the design to add pockets in the aft side of the print to accommodate weights if needed. But adding nose weight is the last resort!
Anyways, this one will go to Colt4570 if he wants it with the imperfections and I will print Mike's tomorrow and get them shipped off. I will contact both you guys to get shipping addresses. Thanks.
bradley (05-09-2022)
Old 05-09-2022, 07:09 PM
  #163
My Feedback: (-1)
bradley's Avatar
QUOTE=JRSmith;12727198]I was able to get the print down to nine hours. I tend to print at slower print speed, typically around 20 mm/s, that way there is virtually no finishing need for the finished part. However, the machine I am using is capable of much higher print speeds and since this part is not that complex, I increased the print speed up to 60 mm/s. This will needed to be fine-sanded, filled and painted to add final details, before installation, so the extra speed will work great. So far the print is looking good. I will send some pictures when finished, but here are a couple to start. Thanks.
Jason
Top RC P-47 Chin Scoop designed by Geoff's son an printed in PETG.[/QUOTE]
BTW. Designer of this Intercooler for the P47 is "Tom Dryer".
Tom is the son of my fellow club member, Geoff Dryer.
Brad
Old 05-09-2022, 07:17 PM
  #164
Oh my gosh Jason, that looks fantastic! I would absolutely be happy to make use of that, but I can't ask you to make something like that for nothing. I would be happy to compensate you for it. If you want to PM me we can talk.
Darrin
Old 05-10-2022, 05:21 AM
  #165
My Feedback: (47)
JRSmith's Avatar
Brad
I hope I did not write something wrong. I never claimed that I designed this and have always given credit to the designer as I should. However, I did not have Tom Dryer's name at the time and thank you for providing that. I should have asked Geoff what his son's name was so I could have given complete and due credit. My sincere apologies.
Darrin
Darrin,
Thanks, I believe its a usable piece, I think I just printed it too fast and I could improve the quality with a couple more tweaks and sacrifice more time on the machine. However, this is a very smooth piece and will need to be sanded and finished anyways and the slight lifting in the corners is aft, so that is a non issue as well.
I appreciate the offer to pay. However, I can not accept any money for this, I am not the designer of the part and I asked for this file for personal use only. I did write that I would print a few for people in the thread if they wanted. I don't want to step on any toes and Tom Dryer did very nice work with the file. These will be the only two I will make for you and Mike and I will not longer offer them. I will design my own parts going forward for this model. Thanks.
Old 05-10-2022, 11:07 AM
  #166
My Feedback: (39)
PaulD's Avatar
Thanks Mike! I just finished the hinges on the left wing as well. For whatever reason, having them recessed like that was also the only way I could get the bay door inboard far enough when opened and out of the way for the gear to clear it when extending.
On another note, every time I handle the fuse to work on it, the sides flexing make me want to remove the cockpit and add formers behind the turtle deck.. Has anyone else done any reinforcing?
Darrin
Darrin, I’ve found the same with the flexible bit. Also noticed that the wood former that goes across the fuse under the cockpit was barely glued in and not at all on one side - so I reached in and pulled on it and it broke away really easily cracking the fuse about 1/2” long.
The only way I can think of to get in there to fix this properly and also do any other reinforcing would be to cut the cockpit tub out. So scratching my head on how to do that….
Slow progress on the build for me. Lotsa conflicting projects non rc related. On a good note I did start bench running the 125….
Cheers,
Paul
bradley (05-10-2022)
Old 05-10-2022, 12:22 PM
  #167
Darrin,
Thanks Jason, I understand now.
Old 05-10-2022, 01:30 PM
  #168
My Feedback: (39)
PaulD's Avatar
Hey guys, I’ve got the other piece that was printed by Tom/Geoff. I think the infill could be reduced to make a lighter part. There’s no structural requirements and it’s pretty solid as is.
pic of mine mocked up in the cowl with the 125 UMS. Will probably trim it down a bit to locate it better.
PaulD
Old 05-10-2022, 07:03 PM
  #169
My Feedback: (-1)
bradley's Avatar
Darrin,
All good. Just giving credit where credit is due.
Tom and Geoff sent me 3D details tonight. Greek to me, but here it is;
Brad
PrusaSlicer 0.15 OPTIMAL preset
fill density: 10%
fill pattern: support cubic
solid layers bottom: 2
combine infill every: 2 layers
61g, 4h 38m
Old 05-10-2022, 07:22 PM
  #170
My Feedback: (47)
JRSmith's Avatar
Brad
fill density: 10%
61g, 4h 38m
I thought I gave him credit, I just did not use his name directly. I never said I designed this part.
Sorry guys to have clogged up this thread with all my stuff, I will move on. Sorry again, I totally did NOT claim credit for the design.
Darrin and Mike, I was only trying to help and I never asked for any compensation, but it might be best if I don't send the parts, I have already deleted the files. This is why I design all parts myself. Thanks and take care guys, best of flying to you all.
Old 05-10-2022, 08:30 PM
  #171
My Feedback: (-1)
bradley's Avatar
I don't believe anyone thought you took credit for the intercooler design? It was very clear in your posts.
update
Designer is offering the file for free to anyone now he tells me.
Old 05-11-2022, 12:16 PM
  #172
Cheers,
Paul
I'm still considering removing the cockpit for access as well, we'll see. Also considering a sliding canopy, but that's a whole other can of worms, lol. That UMS looks good!
Darrin
Old 05-11-2022, 08:16 PM
  #173
My Feedback: (39)
PaulD's Avatar
LOL. I quickly dismissed the sliding cockpit idea…. Else it will be Christmas and we’ll still be talking….
cheers,
Paul
Old 05-12-2022, 08:48 AM
  #174
Got the elevator slots cut. Locating them was a concern, but with the arm on the servo to estimate location, I used a sharpened paper clip bent at a 90 deg angle to poke up through the horizontal stab.
JRSmith (05-12-2022)
Old 05-12-2022, 09:33 AM
  #175
My Feedback: (-1)
bradley's Avatar
nice job!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
