Reload this Page >
help with retract parts
Old 05-30-2021, 09:11 AM
orthobird
Default help with retract parts
Anyone know where I can purchase a straight retract strut that is 230 mm in length and 13 mm diameter at the base?
Old 06-01-2021, 07:12 AM
FlyerInOKC
FlyerInOKC's Avatar
You might be able to use a Robart 1/2" Robostrut #670XL to replace it. 1/2" (12.7 mm) is pretty close to 13 mm sand it is 9.75" long allowing you to cut it to fit. The only question is the airplane's weight, this strut is good up to 26 lbs.
