Continuing the TopFlite P51D giant scale construction >
Old 06-12-2024, 03:05 PM
gonzalobures's Avatar
Default Continuing the TopFlite P51D giant scale construction
Worked hard the past weeks in the fuselage of my Topflite giant scale P51D. I have almost finished the work on it. Constructed a cockpit with details and installed it temporarely. The cockpit is waiting for some details that I need to finish: scale gunsight, engine control quadrant including throttle, prop pitch adj and mixture, pilot seat belts adj, and the joy stick, The canopy is already painted and fitted. Just need to install it.
The fuselage had the graphics installed, the panel lines over the graphics done and also the rivets over the graphics made.
Next step is to finalize the radio installation and test all servos and thier link to the control surfaces. Also the Throttle servo and choke servo are installed, it all matter of routing the wiring, installing the switches and placing the batteries and receiver.
Once that is done, I will do some weathering and then I will give the fuselage coats of clear satin to seal and protect all the finish.
Once i finish the fuselage and everything is ready, I will post the fineshed product.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
