TF GS P47 Build - yeah another bloody one!!
#6851
MO
RE: TF GS P47 Build - yeah another bloody one!!
Tseres, those look like robart gear to me,,, the gray paint is a dead giveaway.
Or i may be wrong? Sierra gear has a cast natural aluminum finish look.
#6852
ORIGINAL: AirplaneMan04
#6853
ORIGINAL: Tseres
You are right. The Wheels are Sierra, the retracts are Robart with Sierra aluminum cam blocks.
The one comment I would add is now that I have some flights on the retracts I will pull them this winter and pin them in the clamp.
Cheers Bob T
#6854
ORIGINAL: rt3232
Yup I have the same set up except I used wheels that I had (robarts) 41/2 with the center relocated and brass bushed, they seam to be handling my 34 lb'er ok.
Cheers Bob T
ORIGINAL: Tseres
Cheers Bob T
Bob. That's a great Idea and a new one for me.
What are you going to use for a pin?
#6855
Sorry Tom I haven't glassed the wing yet, Got my words out of order.
I never store my planes resting on the wheels, Flat spots, Must be biased ply tires!
Ron
Ron
#6856
Banned
ORIGINAL: rt3232
Ok
Did not mean to drive you all away with my spelling so ware did you'all go ??? Pete I know what you are doing its Hot, but stop by and say hi, Tom your all most as old as me so what are you doing???
Bob t
Ok
Bob t
still around mate and yup weather is getting really hot, big dust storms here too
#6857
Hay Ron
Works for me hehe
PS will be in your next of the woods some time in the next 10 days looking for my brother who is a fly fisher ma (he thinks) long story, anyway looking at the weather forcast we may hit billings between storms so to speek hope to see some of the history things.
To far off topic
Cheers Bob T
Tom oh ya the pin well if the clamp stays tight then there is no load so I will be using a 3/32 roll pin in one side only of the clamp, will also leave just enough stickking out so it can be pulled for repair, I would reather have a welded cap on tke clamp on the dtrap, but no one hear seeen to want to do these little jobe
Well for me it it wat bast my punnnnnkin t imee
#6858
Well nothing seems to be to far off of topic. We just inject some friendship into the P-47 build.
We are so Slow at Building that we can't help but form a friendship. [sm=thumbs_up.gif]
Have a Great Vacation!
#6867
Got some good news.
I finally got some time to tear into my muffler that came loose again. The design of the bolts to hold the muffler on was good. I ground off to much of the weld and that was where the bolt failed.
I redesigned it again and this time I redid the Square nut that the bolt goes into. I have always felt that there wasn't enough thread in the square nut to hold the bolt. I modified a 10-24 blind nut to fit in the place of the regular square nut.Now I have twice as much thread in there to thread into. I also mounted the stock exhaust back on the Engine I'll mess around with the Pitts Muffler next spring.
I run out of gas today so I didn't take any pictures. I'll take some tomorrow and post them.
I'm also ketching up with my other projects once again. That means I'm thinking about the 47 again. I'll probably start on the cowl next week.
#6868
Old Tom
If your 62's are like mine reverse the bolts grind the heads so they will slide in then you can use any good qual stop nut on the out side. I had the same problem till I switched. Just what I did.
Well we are off on the yellow brick road in about 2 hrs so will see ya end of the month
Cheers Bob T
#6869
Here it is.
The first two pictures are of the stud setup on the Pitts muffler. That will work when I make a some larger 10-24 studs and I pay attention to the weld penetration.
The new square nut setup I think will work with anything. Because we are running out of flying weather where I live. I decided to mount the stock muffler that came with the engine. Breaking the engine in is my first priority. I eliminated the stock gasket.That has been reported by many to be the cause of the mufflers coming loose and replaced it with high temp copper silicone gasket material. Also used a lock washer and red loctite. I replaced the metric screws cause I couldn't buy any metric square nuts locally. I lost it the first time the muffler came loose.
Hope it works this time.
#6871
ORIGINAL: Tseres
Here it is.
Here it is.
#6872
IN
ORIGINAL: Tseres
Here it is.
Here it is.
I could be all wet, but in the last picture it appears the nut is on backwards.
#6873
Hi Mack. No it's on there right. If you turn it around the small part of the nut would be to long and you wouldn't be able to tighten it. The diameter of the small end is to large to turn around also and it won't fit in the slot. I didn't want to enlarge the slot.
I understand why you taught that. The soldered on square nut is only reinforcing for the flange on the blind nut and to fill up the slot that it slides into.. I tried it out today and it worked for 15 minutes. Couldn't get it started the second time cause the spark plug came loose and burned up the electrode on the plug. Of course I didn't have another one with me. Will give it another shot tomorrow.
#6874
I did a little piddling while my plane batteries were charging.
Just so you guys know that I didn't forget my 47.
#6875
Hey Sam@ATA
How did the Warbird fly go? Got any pictures?
Sorry I couldn't make it. It looked like your weather was a lot better then ours.
