Reload this Page >
WARBIRDPROPDRIVES.COM TOLEDO UPDATE
Old 04-01-2005, 11:59 PM
JoeEagle
My Feedback: (26)
Default WARBIRDPROPDRIVES.COM TOLEDO UPDATE
HI Guys:
Just updated the website while I'm here at Toledo.
The big news for us is that we are now making a Constant Speed Prop
for the Warbirdpropdrives.com Reduction Drive.
Check us out at www.warbirdpropdrives.com
cheers
Joe
Old 04-02-2005, 12:01 AM
JoeEagle
My Feedback: (26)
Default RE: WARBIRDPROPDRIVES.COM TOLEDO UPDATE
oops, forgot the picture
cheers.
Joe
Old 04-02-2005, 01:09 AM
-Fast-Eddie
I saw those today!! ... i'll have to stop by the both again tomorrow to ask some questions
Old 04-02-2005, 08:26 AM
Rayden
Still wondering how your gonna cool it ??
Old 04-02-2005, 09:55 AM
exeter_acres
exeter_acres's Avatar
I took a look at that yesterday...very nice workmanship
Old 04-02-2005, 05:18 PM
CarverTripp
CarverTripp's Avatar
Hello Joe, So that was the surprise! Constant velocity prop, very nice. As you know I've been following your progress for some time now, and I must say it's looking great! One thing I would like to know, how much extra weight is the propdrive and hub assembly going to add to the nose?
Good luck in Toledo,
Carver
Old 04-02-2005, 05:40 PM
dionysusbacchus
My Feedback: (25)
dionysusbacchus's Avatar
Joe, Two questions, how does an engine that tight in a cowl keep cool? Will you ever make a prop that resembles a Corsair set up in the 3 blade 26" range?
Dion
ORIGINAL: JoeEagle
cheers.
Joe
Old 04-03-2005, 03:43 PM
grinder-RCU
grinder-RCU's Avatar
Pic from Toledo. Joe Doing his thing working the crowd. Very impressive looking craftmanship.
Grinder.
ID:	253511   Click image for larger version
Old 04-04-2005, 10:09 PM
JoeEagle
My Feedback: (26)
Yikes!!
good thing that picture didnt focus on my gut...gotta slim down.
anyhow, the weight is on the documents posted on the website (i think) but,
Drive= 53oz
prophub/blades=29oz
yes, i need to lose weight and do does the drive.
as for cooling, here are 3 factors.
1. the nominal prop speed unless you are flying with your hair on fire is 2600 RPM. this equates to 6700 RPM (i think i said 5200 at the show, i was thinking 2:1 ratio). this is quite a bit less than the max rpm of the motor in flight normally, so there should be less heat.
2. The muffler from Keleo Creations is a huge heat sink, and dissapates a lot of heat. its T-6 aluminium, and is an efficient heat transfer mechanism, so that will help
3. there is a lot of unused real estate under the cowl where a cylinder head normally sits. it is a perfect place to put some baffling, so, just like on a full size plane, i expect that some baffling will be required.
it will be a challange, not a show stopper.
as soon as i get the blades, i'll post a pic on the website and link it here on RCU. then i'll do some ground testing to make sure the system works, then go fly the big cap to prove that it works.
thanks to all who stopped by to say hello at the show.
it really was a lot of fun, and i almost have my voice back after talking non-stop for 3 days.
cheers
joe
Old 04-05-2005, 02:42 AM
oifvet23
yes but what will be the cost
Old 04-05-2005, 06:54 AM
JoeEagle
My Feedback: (26)
Hi guys.
the cost will be
Drive including big pulley, small pulley, flywheel, belt, side frame, rear frame
$300
Prop hub includling actuating mechanism, cap, and computer that runs it all
$375
Blades=$30 each
we have a 3 blade and 4 blade hub.
we also think (but haven't proven it yet) that this setup will be powerful enough to fly a 100" wingspan warbird. the pitch change is 40 degrees, and will likely run from 18 degrees of pitch to 45 degrees of pitch in flight. 45 degrees equals about 48" of pitch. plenty of speed there!!
gotta go give a briefing!
joe
Old 04-05-2005, 09:32 AM
mugenkidd
My Feedback: (94)
mugenkidd's Avatar
The price is right. I think those numbers are very resonable. BTW will this hub be able to take a standard P-51 spinner or will you guys have to design a special one?
The hobby has needed this for a long time, please keep up the good work and keep us posted.
Michael
Old 04-05-2005, 02:16 PM
JoeEagle
My Feedback: (26)
Hi:
Just finishing my meetings in Washington, DC.
No, I don't think that anyone has a spinner that will fit this prop/hub.
Yes, we are going to come out with a spinner that will be for our prop/hub combo. We are planning of making it out of composites.
hmm...should i raise the price?? Seriously, we took a stab at resonable and waaaay too much.
Hopefully, this will work out for a bunch of folks.
I am trying to arrange my schedule to make it to Joe Nall. Don't know if it would be flying or just on display.
and yes, i think this thread should stick to the CF bryon blades, i was just trying to answer a question.
I heard that byron had blades at Toledo, but i barely got out of my booth.
Did anyone see them at the show?
Old 04-05-2005, 02:17 PM
JoeEagle
My Feedback: (26)
oops, i thought this was the byron thread.
by all means, this should be the WPD thread!!!!
thanks for all of your interest.
cheers
joe
Old 04-05-2005, 02:53 PM
YAT-28E
YAT-28E's Avatar
when is toledo??
Old 04-05-2005, 04:42 PM
ezflyr
My Feedback: (32)
Joe,
You say "Constant Speed", so I assume that means some sort of propeller govenor, or do really mean "Adjustable Pitch"?
Thanks!
John
PS Toledo was LAST weekend [X(]
Old 04-05-2005, 08:13 PM
mugenkidd
My Feedback: (94)
mugenkidd's Avatar
ORIGINAL: JoeEagle
NO PLEASE NO Thanks for keeping the price resonable, this is definately in my price range.
BTW Without a spinner this setup looks Perfect for an 80in plus P-47 like the top-flight or Yellow, and better yet the P-47 would allow more cooling and probally balance better because radial planes usually need nose weight anyway, I wish Top Flight would release the giant ARF P-47 in time for this. Speaking of release time whats the estimate on having these available?
Michael
Old 04-05-2005, 08:32 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Has anybody considered that if this drive weighs 53oz, it will take at least an additional 24oz at the rear to balance a T/F mustang ARF. Now if you add the total of the drive and the balance weight together, that's over 4 3/4 lbs total added weight, and that does not include the hub and blades.
Suddenly a 21lb plane weighs 26lbs. Now how will it fly?
I think this a great unit and think there are tons of applications for it but not and 80-85" aircraft. it will however be a boom for the larger birds, especially the those with round engines that need a ton of balance weight.
Old 04-05-2005, 08:43 PM
t_burley
My Feedback: (59)
exactly Terry, I was kinda thinking along the same lines. I like the idea of what Joe is doing here.
I can see having a nice FW190A8, short nose German fighter, all decked out, flying scale prop, and
of course all the "correct" markings including swastikas to make it look the part.
with the short nose, all that weight up front would be great.
also the Hellcat, Typhoon, Zero etc would benefit
Old 04-05-2005, 10:22 PM
mugenkidd
My Feedback: (94)
mugenkidd's Avatar
ORIGINAL: TLH101
Like a warbird is supposed to. If I recall several byron mustangs weighed in at least that much and they are the same size as the TF one, for the true scale mustang lover the extra weight will not be a major problem. Even with the reduction drive I don't think the wing loading will be as high as many scale turbine jets. Also just because its designed around the mustang doesn't mean it wouldn't be great in other birds, a big 4 blade will look great in several planes P-47, corsair, bearcat, and skyraider just to name a few that would be on my list.
Build it and we will buy.....
Old 04-05-2005, 10:47 PM
RickVB
My Feedback: (24)
RickVB's Avatar
I hate to rain on everyone's parade here, but I am still coming back to what I asked when Joe posted the prototype what, two years ago... how is this gonna get cooled? I know Joe addressed this above, but I still have extreme difficulty believing that this is going to work. The hottest parts (the head and the exhaust manifold) are in the top of the cowl, where there is the absolute least airflow with this setup. Unless there is room on the sides (and it sure doesn't look like it), with the prop hub and drive gear on the top front and the main drive gear and flywheel behind the bottom front, there's no way in there, and the mount frame is behind that, anyway. On top of that, ducting out through the fuse seems to me to be absolutely manditory, as there's no way your going to get enough air down the back past the carb to go out the bottom, the only other option being to make the exhaust slots in the cowl a lot taller in the back.
I seems to me that I read someone (was it RCShowcase/ZDZ?) who was talking about bringing out water cooled versions of some of their singles. This would seem to be a prime candidate.
I also agree that this drive might be better suited for larger planes that the TF Mustang, but because they would have larger cowls with more room to work out the cooling. I also agree this would be great for the big radial engined planes, but I think it would be advisable to come out with a few longer lengths of prop hubs (different between the drive gear and the blade mounts)to get the drive back out of sight more (to fit a dummy radial).
Joe, since you've apparently got the Eagle Tree Systems telemetry equipment, I think that when you fly your prototype it would be a good idea to put temperature sensors on the top engine area in a few places and collect some data. That would settle this once and for all, I'd think.
Don't get me wrong, I'm as anxious as anyone to see this work (if it does, your guaranteed to sell a few to me ). I'd just hate to see the project get 95% of the way there, and then stop short of perfect. We all appreciate your efforts, Joe.
Old 04-06-2005, 12:37 AM
grinder-RCU
ORIGINAL: JoeEagle
I didn't talk to any of the Byron guys, but was able just to snap an pic of the drive unit.
Grinder.
Old 04-06-2005, 01:36 AM
oifvet23
hey rickvb,
did i hear you say something about liquid cooled engines??? tell us more
Old 04-06-2005, 09:38 AM
MetalWarbirds
ORIGINAL: JoeEagle
joe
Hi Joe,
If you ever want to try it on a P-51D with 111" wingspan, give me a call . We're currently flying it on a G-62.
Old 04-06-2005, 01:26 PM
JoeEagle
My Feedback: (26)
Hi guys,
here are some answers to your questions until i get a FAQ page on the website
yes, its constant speed-governor by ModelAvionics
yes, on board telemetry will answer the question about heat buildup. i can tell you from personal experience when i was testing the 2G drive and 3G drive last year on the 1/3 H9 232 Cap, i had the cylinder head temp up to 280F, but by the time i taxied in it was around 210F. huge difference in the air vs on the ground, where we typically check our temps.
the weight fraction of the drive/prophub/propblades/muffler on the TF-P51 is a larger percentage than say, a Ziroli 90 inch bird or larger. so is the cost fraction.
in other words, i picked the TF mustang because i like it and it was readily available, now it is up to me to make it work.
as for performance, i got over 85mph with a fixed pitch 26x24 3 blade prop on my old design drive last year. i'm not worried about the performance on a 25 or 26# plane. or a 36# plane for that matter
guys, i'll answer more after i get home tomorrow.
going out to fly a trip for work. the OTHER day job.
cheers, and thanks for your continued interest.
joe
