Balsa spitfire kits
Balsa spitfire kits
I am wanting to start a spitfire kit -
Does anyone know a good balsa kit with a 40 - 50 inch wingspan which is electric powered.
Cheers Tom
Cheers Tom
RE: Balsa spitfire kits
Hi
I know about kit in this range, but it is not from balsa
http://www.savex.cz/vrtu.php?lang=en&id=5
It is Mk 5
It is Mk 5
I am more looking for a kit i have to build almost from scratch but with the piece ready cut out, with some pre parts like guns canopy etc
IL
ROYAL PRODUCTS had a 40 size spitfire kit . They are out oif bussiness and MARKITA picked up the line for awhile . If you advertise for one someone will probably have it . Hope this helps . Tom[8D]
Thanks for the advice i may go for the RBC spitfire
see this link [link]http://www.rbckits.com/[/link]
click on aircaft then spitfire
thanks alot Tom
thanks alot Tom
Hi Tom,
Take a look at the Dutch forum, there is something about the Spitfire, prototype for the RBCkits.
I'm sure Ton can give you more information about it.
Here you can find the link http://www.modelbouwforum.nl/phpBB2/...er=asc&start=0
Also take a look at the JEPE Spitfire http://www.jepe.org/index.htm
Good luck
Tom Verstappen
Good luck
Tom Verstappen
Hi Tom,
It's Dutch, not German
Not sure if you can translate it, but you can ask information at Ton, by sending him a mail.
Cheers,
Tom
Cheers,
Tom
My Feedback: (98)
MD
Tom,
If you have not already seen it, take a look at this thread -> http://www.rcgroups.com/forums/showt...=rbc+spitfire+
Paul
Paul
