Top-Flite Sea Fury and OS .61FX
OK, I am getting ready to start building the Top-Flite .60-sized Sea Fury kit and need to know if the OS .61 FX will really fly this airplane.
Will it? I want nice scale power and speed.
Brian
Brian
Richard,
Looks like a Saito 1.20 would do the trick...what prop is the plane in the video running, very impressive performance.
Brian
Brian
If you go with the 61, try putting the throttle servo & battery in front of the firewall, beneath the cowling, & shift the other servos forward (if possible) to reduce the amount of balast needed.
Yea! I got mine tonight, it was too good a deal to pass up. The guy that had it started the horizontal stabilizer, but it will need to be rebuilt, and he lost interest. It was an early Christmas, I'll probably get the engine and retracts by then too. It will get a Saito 1.20 and I'll look at retracts but they will probably be Robart. I will hold off on the giant scale plane for now and practice building techniques on this one.
IN
Mine weighs 12 lbs and flies well on an OS91 turning a APC 15-6. Not a speed demon but most flights are at 3/4 throttle. It took 11ouces on the engine mount so a 120 would be a good choice.
IN
I used Robart 90 degree 605HD One thing to point out is from the front the gear lean in. I would make an effort to mount the gear blocks to fix that but still allow the gear to retract into the wing. I've read about this same gear lean from other owners. I haven't really had a problem from it but it makes your mind wonder on final hoping the gear is down and locked.
