 P-6E Curtis hawk (build thread) >
Old 10-03-2013, 06:15 AM
  #1601
Great to hear... you were able to work on it and fly it.
Life can def. get in the way of geting these planes up in the air....
I have yet to look at mine...
Old 10-03-2013, 06:18 AM
  #1602
Originally Posted by Destroyer of Airplanes
Thanks, but those are the large struts that go between the wings. I need the right side cabane struts that go between the top wing and fuselage.
Thanks again.
Paul
Any luck??
You could always make your own.. alluminum or spruce wood, could work...
Old 10-03-2013, 07:26 PM
  #1603
My Feedback: (14)
radfordc's Avatar
Several of my cabane struts cracked where the screw goes through at the fuselage end. I have repaired them, but am thinking about making some stronger ones.
Old 10-04-2013, 06:20 AM
  #1604
I have got to say....Both Hobico and Horrizon have discontinued planes at a rapid pace....
I realize it isn't anything new..... My guess is tha both tower and Horrizon will start sharing the "Limited runs scenario"
This sells the product quick and discontinues it just as fast....
I noticed that Topflite has discontinued the B-24 twin as well.... Surprising, as it was the only game in town....no
other ARF was close to the quality and size... guess there is always ESM..... for there twins.... Problem is, there ARF's are more of a Yellow Aircraft style kit...
were the wings and fuse are built but it is anything but an ARF.... At least Yellow aircraft has unreal quility.... but you pay for it as well..
if I had the time, I would make some molds of this bird .....and scale it out in the mold....
That would be very cool....as this plane has some amazing detail that isn' available in a ARF... wood built up....
Old 10-04-2013, 06:42 AM
  #1605
Lifer's Avatar
If you see something you like, buy it now. It will be gone sooner or later. If you really like it, buy 2!
I wish I had bought the P6E as well as the TF B-25.
Old 11-04-2013, 07:31 PM
  #1606
My Feedback: (14)
radfordc's Avatar
Here is a link to a video of the Hawk: http://youtu.be/QWUW-jFBTKY
<iframe width="420" height="315" src="//www.youtube.com/embed/QWUW-jFBTKY" frameborder="0" allowfullscreen></iframe>
Old 11-05-2013, 02:45 AM
  #1607
Lifer's Avatar
radfordc,
Where is your field located?
Old 11-05-2013, 09:31 AM
  #1608
My Feedback: (14)
radfordc's Avatar
Originally Posted by Lifer
radfordc,
Lansing, KS
http://www.rcgroups.com/place/5600-s...lub-lansing-ks
Old 11-06-2013, 06:58 AM
  #1609
My Feedback: (68)
SunShyne's Avatar
Agreed its a shame. Mine is going to get a new engine and now I cant find a replacement cowl.
Old 04-10-2014, 06:19 AM
  #1610
My Feedback: (24)
RickVB's Avatar
OK, try again. (First post here didn't go through.)
After about five weeks of reading, I finally made it to the end of this thread. Lots of good information here, but I hope there are still some watchers, as I have a couple of questions.
I've recently purchased a Hawk new in the box from someone here on RCU, and I am mulling over powerplants. I am leaning strongly towards gas, and I note that a few of you have mentioned using or planning to use a DLE-20. Anyone care to share the details? How about some pictures?
I have also wondered reading this thread, that few if any have mounted an engine vertically, even though it appears there is more room that way. I realize that this poses a cooling problem, but I am not opposed to engineering a proper ducting system to take care of that. Any thoughts?
Old 04-10-2014, 06:38 AM
  #1611
I just received my Extra parts for the Hawk....
Tower hobbies had the Fuse and Tail Feathers on Closeout prices ......
I now have a Fuse, Cowl, Bottom wing, and Tail feathers.......For the JIC.....
I may however, create a Mold for the landing gear pants.....Those at a work of Art IMHO......
However.....It seems the Struts could be improved?....... Could make them out of wood, Alum, stainless Steel...?....
I want to mold the top wing and pants befor I take it up and risk loosing it all.....
Old 04-10-2014, 06:42 AM
  #1612
why have the Cyl. pointing up with a Gas engine???? Install it per instructions and you will not be disappointed......
Also.... having the engine head and ignition poking through the TOP of the cowl, seems counter productive..... (perhaps I read that wrong??)
Old 04-10-2014, 06:55 AM
  #1613
My Feedback: (14)
radfordc's Avatar
I am glad that I used a DLE 30 in my plane. I think that it would be underpowered with a 20cc engine.
Old 04-10-2014, 07:04 AM
  #1614
My Feedback: (38)
tlroliff's Avatar
I have been flying a Hawk with a DLE-20 for several seasons and IMHO it is the perfect match. (Started with a Saito 150 but I am done with glow completely) It is inverted with nothing extra done to the cowl other than clearence for the head. No cooling or any other issues. If you fly it like a real airplane it is more than enough power. If you want it to be an aerobat and hover I am not your guy. I dearly love this airplane! Don't have any pics of the engine install but I will probably have the cowl off doing preseason checks and can take some. Feel free to PM if you have other questions.
Old 04-10-2014, 07:45 AM
  #1615
My Feedback: (24)
RickVB's Avatar
As I said, it appears that there is more room that way. The goal is to avoid cutting any holes in the cowl. I will only cut as a last resort. Obviously, holes in the top of the cowl are completely unacceptable, so if nothing will fit mounted upright without cutting, then going that route that would be out.
Old 04-10-2014, 08:14 AM
  #1616
My Feedback: (24)
RickVB's Avatar
Thanks for the update, I will look forward to photos if you get the chance. Are you using the side exhaust version, or the rear exhaust? From what you've said, the head does not clear the cowl when mounted inverted, which is disappointing to hear. I wonder if you are using the side exhaust version, and if the RA version with it's canted plug might just make it?
I am definitely the scale flyer type; 3-Ding a plane like this is an anathema to me. It appears from what I read that while not comfortably, this model will fly with a .90 four stroke, thus a 30-40cc or more gasser is completely uncalled for. To me, throttle management does not address the extra weight, vibration and dynamic loads that an airframe was not designed for, so I avoid overdoing the engine.
Old 04-10-2014, 08:18 AM
  #1617
My Feedback: (38)
tlroliff's Avatar
Yes it is a side exhaust. The head does not quite clear but it is close and on the bottom so not bad. The RA might be a solution.
Old 04-10-2014, 08:24 AM
  #1618
Rick....
I hope I didn't offend you.... it wasn't my intention.....
The cowl is huge though.....I had thought about a os 1.60 twin but the heads would poke out the sides and the carb and the old C&H ignition system would have wrecked the front of the cowl....
I wished the OS 1.60 twin would have a EXTENDED crank shaft, as it would make installments a Snap...
I think the dle 20 rear or side mount, would fit w/o cutting in the side of the cowl.
Post some video when you get it all set up....
Justin
Old 04-10-2014, 08:52 AM
  #1619
My Feedback: (24)
RickVB's Avatar
Justin,
No offense taken at all. I have been doing online public communications since before these places were even called "bulletin boards", so I'm entirely aware of the difficulty in getting what you really mean across in this type of venue.
Did some digging way back in this thread, and I offer as evidence for my idea the diagram that Wile E. did eight years ago, showing his FPE 1.3 in the nose. I apologize for the mess, but it's the best I can do with the limited tools I have on this computer. I have cut and flipped the 1.3, which is very close in dimensions to the DLE-20. It's rough, but it appears that it could clear the intake duct on the top, which might mean it would fit upright.
Of course, that doesn't address what to do with the exhaust, but if Keleo will still do one of those wonderful scale exhausts... (anyone know if he's flexible recently?)
Name:	GP P-6E with FPE 1.3 flipped.jpg
Old 04-10-2014, 01:05 PM
  #1620
My Feedback: (43)
Rick,
If you're thinking the engine will be more reliable in the vertical, I have run all my engines inverted with no problems. Even in the 'old' days when I had glow, I always inverted my OS engine and they ran perfect. If you're worried about hydrolock, I start my gas with the ignition on and the choke closed, after the first 'pop'. I open the choke and she usually starts in a few turns. The ignition on tells me that she's ready to fire and there's little possibility of flooding the engine with this procedure.
Also, if you're worried about kick backs, I, virtually, start all my gas engine by hand and have never had a kick back (not saying it can't happen but if it does, it's extremely rare).
As for engine power: I really like gas, extremely reliable; once set the engine rarely needs adjustment, independent of outside temp and humidity, fuel is cheap and no residue, or very little, to clean off the plane. Very rare to have a plug go bad while flying.
ps: man, this is one old thread. I started this thread many moons ago in Sept of 2005!
Old 04-10-2014, 02:21 PM
  #1621
My Feedback: (24)
RickVB's Avatar
Sam,
None of the above. I am purely looking for the way to get the best fit, ideally with zero non-scale cowl openings. I have mounted engines every which way in the past and the only thing I've noted with any orientation is that four-stroke glows sometimes hydro-lock if you flood them mounted inverted (not too hard to avoid). Otherwise, whatever fits.
I had forgotten who started this thread after five weeks of reading this; welcome back!
Old 04-10-2014, 06:43 PM
  #1622
My Feedback: (14)
radfordc's Avatar
I doubt that there's much weight to be saved with a smaller engine...you still have to have weight in the nose to balance the plane. I prefer to use a larger engine with a more scale looking prop and run it slower. The sound of a .90 glow screaming it's guts out to haul this plane around would be "anathema" to me.
Old 04-11-2014, 07:24 AM
  #1623
My Feedback: (24)
RickVB's Avatar
Not to start the old argument again, but I need to point out that many, including Dick Pettit, have managed to balance this plane perfectly with a 1.20 four-stroke, with zero extra nose weight. This is a 13-14 lb. plane, when equipped right. Unless you are trying to fly a 13 lb. brick, you don't need a 40cc to power it. And at a 21 oz/sq ft. wing loading, this does not qualify as a brick.
Old 04-11-2014, 07:41 AM
  #1624
My Feedback: (24)
RickVB's Avatar
Well, Keleo turned me down..
Anyone out there have one of his exhaust systems for this plane they want to part with?
Old 04-11-2014, 08:08 AM
  #1625
My Feedback: (43)
Rick,
Yep, I had an OS 1.20 4 stroke in mine and she flew great.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
