Reload this Page >
P-6E Curtis hawk (build thread)
Old 08-03-2015, 09:18 PM
  #1776
marksp
My Feedback: (9)
marksp's Avatar
Here's a couple of pictures from last weekend -
Old 08-06-2015, 08:15 AM
  #1777
RickVB
My Feedback: (24)
RickVB's Avatar
Holy cow, that last photo would make a great magazine cover...
Old 09-09-2015, 08:40 AM
  #1778
Capt Easy
Good to see some interest in the GP P-6E. I'd built one about 8 years ago and now finally getting around to flying it. It's an EP conversion with mods and scale additions.
I don't recall if the wing brackets are different from top or if it makes any difference to the relationship of the wings. I've assembled it for the first time in a while and the right wing needed slight adjusting to fit the top brackets. I have the smaller version P-6E as well and it required attention to be certain the brackets were oriented correctly.
Thanks for the help.
Dick
Old 09-09-2015, 11:16 AM
  #1779
radfordc
My Feedback: (14)
radfordc's Avatar
The wing mounts are different. See page 22 in the manual....
http://manuals.hobbico.com/gpm/gpma1219-manual-v1_1.pdf
Old 09-09-2015, 12:18 PM
  #1780
bufordbob
The wing mounts are the same it is the N struts that need proper orientation , checked page 22 to make sure and it is what I said . But of course I built this plane last year and I could be wrong. BTW I don't use screws to hold the struts to the brackets I use Horizon Hobby cross drilled rivets with pins,make assembly a bit easier.
Bob
You will love the way this plane flies,it is great.
Old 09-09-2015, 08:06 PM
  #1781
Capt Easy
I know the short legs of the "N" struts must face the LE.The manual doesn't mention if the hardware brackets that connect the struts and wings are the same top and bottom. Since the manual for the larger P-6E doesn't mention anything about the brackets I guess they're all identical and interchangeable top or bottom
What made me curious was that the new, smaller 43" P-6E EP ARF manual states the wing brackets are slightly different top and bottom and it's important to orient them correctly.
Thanks boys,
Dick
Old 12-20-2015, 07:43 AM
  #1782
Wild Doogie
Your guidance is needed please.
Looking for your experience as to which gas 2 stroke or 4 stroke motor fits the best in the cowl of the Curtiss P-6E. Also a little info on the flight/power performance for that motor.
I'm leaning towards the DLE 30 or DLE 35RA or the DA 35. I would like to minimize cutting the cowl as we all would. I'm mixed on the 4 strokers....sound cool but the performance might be an issue...not sure. I have read mixed views on the 2 v/s 4 gas engines performance.
Thanks to all!
WD
Old 12-20-2015, 08:10 AM
  #1783
radfordc
My Feedback: (14)
radfordc's Avatar
I have a DLE 30 in mine and would not want less power. A DLE 35RA should fit nicely.
Old 12-20-2015, 08:15 AM
  #1784
radfordc
My Feedback: (14)
radfordc's Avatar
Here is a pic of the DLE 30 installed.
Name:	P6 cowl (2).JPG
Old 12-20-2015, 12:15 PM
  #1785
marksp
My Feedback: (9)
marksp's Avatar
I have the DLE35RA fitted with Xoar 17x8x3 prop. Flies wonderful!!! I did have to add quite a bit of weight in and around the engine/motor box to get my preferred slightly forward CG. Also I opened the both the top & bottom air inlets to manage temps - works well.
Old 12-20-2015, 02:15 PM
  #1786
Wild Doogie
Thank you Gentleman for the photos and feedback! Do you know of anyone installing a 4 stroke gasser? I have another question....servo ounces of torque would you use in the beauty?
Old 12-20-2015, 03:27 PM
  #1787
bufordbob
Have this plane for a year now,it is the best and most relaxing biplane I ever owned,while I did power it with an Electric motor(Rimfire 1.20) it is a wonderful flying plane and rarely use more than 1/2 throttle,servos I used were Hitec 100 oz analogs with metal gears way more power than needed. Enjoy it.
Old 12-20-2015, 03:37 PM
  #1788
ToolJoint
Mine has a Saito 150 in it. I'm not particularly impressed with that set up as I think it could use a litte more umph, especially at our elevation (around 5,000 msl) What I am really not impressed with however, is the the fuel consumption of the big Saito....about 6 flights per gallon. I like 15% pure synthetic which runs close to 30 bones for a gallon at my LHS. I'm switching to gasoline at the next opportunity. I'm having a hard look at the EME 35, DLE 35 RA and am studying the NGH 38 Four stroker....These pictures are making the decision to switch to gas much easier, I must say...great setups.
Old 12-22-2015, 08:06 AM
  #1789
marksp
My Feedback: (9)
marksp's Avatar
EME35 + starter sounds interesting. convenience and safety
Old 12-22-2015, 09:16 AM
  #1790
radfordc
My Feedback: (14)
radfordc's Avatar
Hopefully the EME 35 with elec start works better than my EME 55 with starter. The main starter gear failed after the first 5 starts. Mile High RC sent me another gear and told me to lube the gear with a specific lubricant. The second gear also failed after about 5 starts.
At $50 a pop I can't afford to keep replacing main gears.
Old 01-02-2016, 03:13 PM
  #1791
vfourmax
Hey Guys, Been following his thread for a while as the P-6E is one of my all-time favorite planes. I left the hobby about 20 years ago and sold an un-built Royal kit that I now regret selling. Upon returning to the hobby now I was stoked to learn of the GP kit then dejected to see it was discontinued.
Persistence paid off though, I was able to find and pick up a completed plane in excellent shape with a G-26 mounted in the nose. Then I got really fortunate or better yet lucky and this weekend was able to secure a NIB example that even the plastic bags holding the parts had never been opened. I am planning on installing a DLE 35 in the new one when she gets built.
Just wanted to say hi to you guys from a new P-6E owner!
Old 01-02-2016, 04:59 PM
  #1792
bufordbob
vfourmax,
Welcome to the club,you will love this bird she is a sweet heart,read my post about my maiden flight,mine is electric but they basically all fly the same,light wing loading and just a ***** cat to fly.
Cant believe you found 2, amazing luck,now you have a complete supply of spare parts.
Bob
Old 01-07-2016, 12:14 AM
  #1793
RickVB
My Feedback: (24)
RickVB's Avatar
I don't recall reading anywhere in this thread; has anyone noticed that that struts on this model are located about 2 1/2" too far outboard vs. full scale, and appear to be canted a few degrees too upright? Anyone got a reference that shows this different?
Old 01-07-2016, 08:56 AM
  #1794
RickVB
My Feedback: (24)
RickVB's Avatar
I sure wish Bryan Austin (CurtissHawkP6E) was still around...
Old 02-07-2016, 06:27 PM
  #1795
marksp
My Feedback: (9)
marksp's Avatar
Anybody out there happen to have GPMA2853 Cabane struts they're willing to part with? Had a transport issue and cracked mine
Cheers
Old 03-14-2016, 05:49 PM
  #1796
Stick Time
Skinny Bob,
I think I have purchased your P6-e Hawk. It has Skinny Bob under written under the pilot. I live in Tennessee. Could you tell me the manufacturer of the engine, please?
Old 03-16-2016, 04:15 PM
  #1797
proteus_X3
My Feedback: (16)
Hi gang I've want this plane since it's reissue in 2010,just never found one NIB and a fair price until this past weekend at Lebanon sweep meet! I have to finish a FW190-dora and a Hellcat and than shell be next.I have a spare Dle35 RA wait for her.Cheers: Rich
Old 03-17-2016, 06:07 AM
  #1798
marksp
My Feedback: (9)
marksp's Avatar
Wow...that's quite a find!
DLE 35RA is a ton of fun and turns the "scale-like" WWII 3-blade Xoar
Cheers
Old 03-17-2016, 07:21 AM
  #1799
proteus_X3
My Feedback: (16)
Marksp,
Thanks I thought so too,I got lucky and picked it up for $300.00 NIB I was thinking about adding smoke to the plane,but only remember reading one post that body add one, anybody else running smoke? I would like some input on your set -up please. Cheers: Rich
Old 03-17-2016, 07:58 AM
  #1800
birddogs2
Marksp,
What size 3 blade prop are you running on your DLE 35RA? I have a NIB P-6E and am thinking about putting it in the P-6. Thanks.
Bob Mc
