Taking off with flaps deployed?
My Feedback: (17)
TX
Thinking of taking off my WM P51D 60 size with a bit of flaps deployed. For you all who have flaps on your planes, do you deploy them down a bit before take off say 15 degrees or so? I've been flying it for about 4-5 months now and have never used flaps for take off, just getting a bit curious I guess. I'm interested in what you all do. Lemme know what you think.
thanks,
thanks,
My Feedback: (38)
CT
I have deployable flaps on my Hangar9 Mustant PTS (added optional flap servo), and it makes take offs a lot easier. Plane needs much shorter takeoff run, and on landing glides forever with flaps down.
AZ
On the full size, flaps optional on take off but could be deployed up to 20 Degrees (reference pilot check list). The P51 flaps at 20 degrees where rated to 275 MPH. If operating from long good condition field, usually none; however, short fields 15-20 was not uncommon. If you run with move than just a few, your tail will come up quick and it will want to nose over, so don't give to much and watch elevator or you'll grind your prop!
IN
I have used flaps on take off for both the TF Corsair and Sea Fury. I've used around 1/4 flap about 10-15 %. The Plane lifts earlier but is less aileron responsive and requires rudder control until more flying speed is achieved. neither plane needs this but it is for kicks and giggles. Just be aware it is still a warbird and can be pron to nasty habits.
I have also used about 15deg. flaps on take off my TF P51 (1/6). I couldn't really notice much difference . Only that you need less runway and be a little bit gentle with the power because of nosing over...
NE
I tried landing with about 20 degrees of Flaperons with my Hangar 9 P40 and that was a bad idea. She was listless to aileron corrections! I know that true flaps is night-and-day to flaperons though...
My Feedback: (90)
ORIGINAL: driedjello
My Feedback: (9)
I've used flaps on takeoff but find that I forget they are down once in the air. Notice the plane is out of trim and retrim it and wonder why it flies so different. Eventually I figure it out but by then the plan for the flight is shot and the flight is wasted. It did not happen everytime and if I stuck to it the forgetting would stop. But I'm only doing it to be scale like and the only time they would be use by the full size is for short field or taking off fully loaded. So if I ever model a plan with drop tanks or bombs I'll be more dilagent at it.
Joe
Joe
Any degree of flap deployment was only used for shrot field take-offs, brakes on full power hang on. Our models just don't need this type of risky manuver. If it aint broke don't fix it! It may live to fly another day. Jason
