Hellcat g-26 problem
I'm not getting any spark on my g-26,is there a way i can check to see if its the ignition coil,source coil,or the spark plug??Thalnks for any help,everything else is complete.I always end up having something go wrong!
My Feedback: (95)
Check out the Gas engine forum, you might find some help over there. Also don't forget to check your on/off switch, they too can fail. One more thing, Make sure the red wires going from the mag to coil are firmly connected behind the engine. They tend to be a bit short on length, and it's easy for them to get pulled apart.
