CMP paint removal
Old 02-26-2006, 10:43 PM
paladin
My Feedback: (9)
Default CMP paint removal
I just got a CMP Focke Wulf and an looking to remove the factory paint. Any saggestions what to use?
Joe
Old 02-26-2006, 11:31 PM
HalH
My Feedback: (12)
Default RE: CMP paint removal
Judging from the CMP Hellcat I would say it would be best to remove the covering and recover. The fuselage could be just sanded and repainted.
Old 02-27-2006, 11:18 AM
Broken
Broken's Avatar
Be patient!! The paint will remove itself
Old 02-27-2006, 01:39 PM
bosssman
My Feedback: (35)
I would get some 0000 or even 000 steel wool and along with plain ol' lacquer thinner, the paint shoud come off preserving the gel-coat and the panel lines. I also agree (and have personally done so on my CMP birds) to remove that crappy covering. My latest acquisition was the 140 size P-40 and I made sure to keep it in my house rather than my workshop and STILL the covering has started to wrinkle. You may want to check out the CMP Hellcat thread and following along on what Luke is doing - he has COMPLETELY stripped the plane down and done several mods, basic things that can be done to the FW - I also picked up the FW at the same time with the P-40, what retracts are you planning to use?
randy
Old 02-27-2006, 03:18 PM
jeffk464
Could always use DOT approved brake fluid. Dont know what it will to the fiberglass.
Old 02-27-2006, 10:09 PM
paladin
My Feedback: (9)
Thanks guy's .
I'm mostly concerned about getting the paint off the fuse without damaging the fiberglass/gel coat. Worse comes to worse I have mineral spirits, turpentine, Acetone, lacquer thinner, and a couple others I cant think of off hand I'll have to test on the inside of the wing saddle and let sit for 24 hr. Then the ones that pass that test will get tried on a wing to see how affective they are on the paint. Worse comes to worse I know raw fuel will do the trick at a very high price though.
So the covering on the wings is not so good. I was thinking of pealing it back to put correct sized ailerons and flaps in. Any body done that and how did it fly? It sounds like I should just remove the stuff, but replace it with what? Then as long as I've stripped the wings of covering what's under it? Balsa? Obachi? Then how about the retract mounts. Are they typical Lt ply plate hot glued in white foam? How does that hold up? I'm thinking if I've gone this far I might as well re-enforce the LG also.
I plan to use spring air retracts with 660 robostruts.
Joe
Old 07-03-2011, 03:09 PM
keelhaul
Perhaps someone can help me. I have been flying a CMP P-51  140  (with an OS 91 as a power plant) for a couple of years and it has some hanger rash. Does anyone know what paint type and color were used to paint this model. I would like to touch it up but have been unable to match the paint color.
My e-mail address is:  [email protected]
Old 07-03-2011, 05:02 PM
SCALECRAFT
My Feedback: (13)
SCALECRAFT's Avatar
CMP uses a cheap polyester resin. any chemical method will turn the fuse to a "gummy" fuse. Just light sand.
Steve
Old 07-13-2011, 08:40 AM
mikefrench1
My Feedback: (28)
I was just looking on line and there are liquid paint removers for fiberglass. This may work without damaging the panel lines and rivets.
Old 07-13-2011, 11:25 AM
Avaiojet
Really?
Pound for pound, Epoxy resin costs less.
Maybe it's cheap Epoxy resin?
I was always lead to believe that these great fiberglass ARF parts were of Epoxy resins. You never know who to believe.
Here's my two cents, or I should say, my two CMPS.
ID:	1634792   Click image for larger version
ID:	1634793   Click image for larger version
ID:	1634794   Click image for larger version
ID:	1634795   Click image for larger version
ID:	1634796   Click image for larger version
ID:	1634797   Click image for larger version
ID:	1634798   Click image for larger version
Old 07-13-2011, 12:16 PM
Whistling Death
Whistling Death's Avatar
ORIGINAL: Avaiojet
CMP uses a cheap polyester resin. any chemical method will turn the fuse to a ''gummy'' fuse. Just light sand.
Really?
Epoxy resin costs 2-3 times as much as polyester resin.
CMP fiberglass planes are made from polyester resin.
Old 07-13-2011, 01:22 PM
Avaiojet
I just love getting to the bottom of things, even if I'm wrong about something.
Right or wrong, here's some good and informative reading.
http://www.douglasandsturgess.com/Ho...sins-Howto.pdf
