H9 Corsair flaps
#153
MN
ORIGINAL: Flight 21
Hey Craig,
Looking great. Where did you get your pilot? Thanks...
john
Hey Craig,
john
http://www.horizonhobby.com/Products...ProdID=HAN8315 H9 makes 1/7 and 1/9 scale US WWII pilots. I calculated the H9 Corsair fuselage is roughly 1/7.75 scale. Even though 1/7.75 is closer to 1/7 than is 1/9, I went with the 1/9 scale because that size H9 pilot seemed to match pilot size in full scale Corsair photos better. I don't know why that is. Maybe the H9 1/9 scale pilot is actually bigger than 1/9 scale, or the photos of full scale Corsairs that I used for reference had shorter than average pilots piloting them.
#154
Thanks for the info Craig. Yes I agree that his size looks about right, and according to my literature he sits at the correct height too. Yoiu also gave him quite a nice paint job!
On another note, is that a TT prop hub and a 3-blade prop? If so, where did you find it? And what prop/engine combo are you using? My apologies if you have already been through this somewhere else in the thread. Thanks again...
john
john
ORIGINAL: Craig-RCU
Thanks, John. I went with the 1/9 US WWII Pilot by Hangar 9.
ORIGINAL: Flight 21
Hey Craig,
john
Hey Craig,
john
#155
MN
Thanks again John. I'm using a Super Tigre G-90 with a pits muffler turning a 14-6 2 blade Master Airscrew. The spinner is a Tru Turn 1 1/4" hub that I got from my local hobby store. They didn't have the flanged hub in stock at the time, so I bought the unflanged version and added a flange with layers of aluminum tape. Tower hobbies has this hub too. Both the flanged and unflanged versions of the 1 1/4" seem to be in stock at the moment.
http://www3.towerhobbies.com/cgi-bin...+hub&search=Go
#157
My Feedback: (7)
ORIGINAL: Craig-RCU
Thanks again John. I'm using a Super Tigre G-90 with a pits muffler turning a 14-6 2 blade Master Airscrew. The spinner is a Tru Turn 1 1/4'' hub that I got from my local hobby store. They didn't have the flanged hub in stock at the time, so I bought the unflanged version and added a flange with layers of aluminum tape. Tower hobbies has this hub too. Both the flanged and unflanged versions of the 1 1/4'' seem to be in stock at the moment.
I'll be starting on mine when I get all parts and do flaps. I haven't decided on engine yet and see that you use the Supre Tigre 90.I have a spare one but wanted to go with gas. How doe the ST90 perform on yours??
Thanks for the great flap details
JT
#158
My Feedback: (12)
MT
Check these out if you're looking for gas. The RCGF engines are excellent motors w/ great quality and low prices. The 20cc side carb is a perfect match. Got one in my Corsair and P-47. Here is the name of the official US distributer aerovate engines. Shane
#160
My Feedback: (12)
MT
Goose,
The H9 Corsair. I have only dry fitted it as I'm in the process of starting to remove all covering and glassing it before final install. It fits nicely inside the cowl with minimal cutting other than for the muffler and a hole for the carb, which doesn't stick out I just make a hole for air flow as I will add a venture later as well.
Shane
Shane
#161
Aha... that is very interesting.
I am [link=http://www.rcuniverse.com/forum/m_8454945/anchors_9202680/mpage_7/key_/anchor/tm.htm#9202680]bashing[/link] my H9 and only recently started looking for a gas solution and one that might throw a nice big 3 bladed prop when I discovered the Aerovate.
Hmmm... just realised it is twice the weight of the OS 75AX. Mine flew really well with an OS 61FX...
Keep us up to date mate...
Cheers
Goose
Cheers
Goose
#162
MN
ORIGINAL: jtbuck
Craig,
JT
ORIGINAL: Craig-RCU
JT
#163
My Feedback: (12)
MT
The Aerovate engine does weigh in at around 38oz, actually lighter than most other engines in its class. I sheeted the vert and horz stabs on the H9 P-47 and the CG was perfect with the ign between the standoffs and the batts on the CG. I will be doing the same for the Corsair and hopefully it will have the same results. I like them with a tad bit of weight in them anyway, helps stabilize the tail waggle.
The other day I got the urge to fly in again before tearing into it. We just moved from CO and I really wanted to see how the Saito1.25 runs here @3500' elv., that and I haven't flown it in a few months. I was at about 5600' before. I was using a MA15X7 3bld prop and is was very good for scale speeds at the higher alt. and a 16X8APC for more speed. Well the 3bld here is actually faster than the 2bld prop was there. And it sounds really cool on high speed passes. Going to tune the motor a little and throw the 2bld on for the last run and see what it will do. Anyway here's the video, my 9yr old daughter toughed out the cold wind and my 21yr old son sat in the van cause he was cold. Guess if I put a Nintendo controller on it he would've helped. LOL
[link]http://www.rcuvideos.com/video/H9-Corsair-Saito1-25-MA15X7-3-b[/link]
Shane
Shane
#164
Hey Viper...
Ha! You just swayed me back the other way to be on the pro side of the Aerovate fence... [:'(]
Have you flown the P47? Pics? Video?
Yeah, kids eh... Nuff said.
Cheers
Goose
Cheers
Goose
#165
My Feedback: (12)
MT
Goose, videos I do have.. Here are a couple for ya.
Enjoy,
[link]http://www.rcuvideos.com/video/H9-P-47-New-RCGF-20cc-Engine-te[/link] First flight with motor.
[link]http://www.youtube.com/watch?v=pVF3NVNMZe0[/link]
Shane
Enjoy,
Shane
#166
My Feedback: (12)
MT
If you do decide to go the RCGF route, be sure to go through Aerovate. They don't get the same motors as the ones being sold here on RCU or ebay. Henry aka "Piston" works with the factory to develop motors to meet his specifications and his warranty program is top notch. Bill Jensen does his warranty work and he is top notch. He literally tests his motors to the point of destroying them to be sure they are up to his standards. Every motor I got from him has been run and tested prior to shipping as well.
Shane
Shane
#167
ON, CANADA
ORIGINAL: Garthwood
Craig...........Pictures of the jig positioned. Similarity between your jig and TF. Marking first where the holes are to be drilled. I have used a K&S 5/32"nd. aluminum tubing glued on to a jig cut out from a/c ply. A Higley long 1/8" drill bit used to drill the holes, important to mark with tape the depth. I've used the same jig to drill both the TE of the wing, and the LE of the flap, very similar to the TF47 idea. Last picture is for the TE of the wing. (Bottom of the wing). Not sure if it will work for your scale method. I did not have to cut into the LE of the flap.
I am not sure where I'll be placing the flap servo. I know for sure that I'll be using one servo in each wing. I thought I might place the servo near the wing root to activate the inboard flap, perhaps mid way. I can't at this moment figure out the geometry of the end result, how this is going to effect the inner flap and if there will be any binding.
Your comments are welcome. Thanks.
I am definitely late arriving at this party, but Iam here and have questions about this drillingjig. My flaps will be structurally very similar to yours, Ihave already got the left wing all shaped and all Ineed to do is mount them. My questions are:
1. Can you post a flat picture of the jig with a ruler next to it so Ican get a feel for the angles?
2. how did you cut the slots in the inner &mid flap to mount the web so they were clean? Iplan to make my web out of a pop can glued to a piece of flat, clear plastic then shape as required.
3. Did your link pins work out ok? Did they slide only in and out of the sides or did they alos move along the plane of the flaps? Iam not sure but Imight use some brass tube inserted inside a larger diameter brass tube to allow them to slide with some slop to avoid binding.
Iplan to use Craig's internal T-rod idea to keep the lower winf profile clean. Still trying to decide if a 2.7kg-cm mini servo will do the job or whether Ineed a standard sized 6kg-cm servo, what have you guys used and how do you find the operation?
#168
ON, CANADA
ORIGINAL: Dangaras
Garthwood,
I am definitely late arriving at this party, but I am here and have questions about this drilling jig. My flaps will be structurally very similar to yours, I have already got the left wing all shaped and all I need to do is mount them. My questions are:
1. Can you post a flat picture of the jig with a ruler next to it so I can get a feel for the angles?
2. how did you cut the slots in the inner & mid flap to mount the web so they were clean? I plan to make my web out of a pop can glued to a piece of flat, clear plastic then shape as required.
3. Did your link pins work out ok? Did they slide only in and out of the sides or did they alos move along the plane of the flaps? I am not sure but I might use some brass tube inserted inside a larger diameter brass tube to allow them to slide with some slop to avoid binding.
I plan to use Craig's internal T-rod idea to keep the lower winf profile clean. Still trying to decide if a 2.7kg-cm mini servo will do the job or whether I need a standard sized 6kg-cm servo, what have you guys used and how do you find the operation?
ORIGINAL: Garthwood
Craig...........Pictures of the jig positioned. Similarity between your jig and TF. Marking first where the holes are to be drilled. I have used a K&S 5/32''nd. aluminum tubing glued on to a jig cut out from a/c ply. A Higley long 1/8'' drill bit used to drill the holes, important to mark with tape the depth. I've used the same jig to drill both the TE of the wing, and the LE of the flap, very similar to the TF47 idea. Last picture is for the TE of the wing. (Bottom of the wing). Not sure if it will work for your scale method. I did not have to cut into the LE of the flap.
For flap web I used thin stainless aluminum (Home Depot). I used a 4-40 wire for pin. I decided to make two webs to join outer/to middle/to inboard flap. The most important to have a web is the mid-to-inner. Important to note the location of the Robart pin hinges, they have to be even. My mid flap Robart pin hing is 1/2" distance from the edges for a better geometry. The inboard are also 1/2" from the edge. The Outer flap Robart hinges are at 1"from inner and outer edges. You have to test before you permanently glue in the hinges. Craig had his mid flap pushrod almost as scale. He explains how he did his. I took the different route as the Top Flite.
At first is like trial and error so don't rush the job, take pictures and make drawings. For your web cut-out slit, you might have to clean out some of the flap's ribs otherwise the web/wire will bind, and that is done by removing some balsa sheating and replace it again, some restructering have to be corrected inside the flap. The web/wire should be slightly bent to take the curve down shape of the flap. One side of the web and pin should be glued in. The metal web should be glued in to the mid flap and the pins should be glued in to the outer flap and the inboard flap. There should be a slit for the pins and another longer slit for the web........there should be no binding.
Hope this will help.
Charles.
#169
ON, CANADA
Charles,
thanx for the details. You have definitely helped me with the Inter-web. Ithink I will stay scale with the inner web only.
What Iwas trying to figure out was the angle of the tube to the flap lower surface as shown in the attached picture. Since the original picture is not of the jig face on, Ican't be sure Iam measuring the angle correctly.
#170
ON, CANADA
ORIGINAL: Dangaras
Charles,
thanx for the details. You have definitely helped me with the Inter-web. I think I will stay scale with the inner web only.
What I was trying to figure out was the angle of the tube to the flap lower surface as shown in the attached picture. Since the original picture is not of the jig face on, I can't be sure I am measuring the angle correctly.
Charles,
The jig is to be used for the LE of the flaps and the TE of the wings. This was a modification, the angle might be different than yours.
Charles.
#171
ON, CANADA
ORIGINAL: Garthwood
DANAGARAS..................I used the same idea as the TOPFLITE Corser Robart hinge point operation but the P47 jig idea (not quite similar).
Charles.
ORIGINAL: Dangaras
Charles,
Charles,
Charles.
my wing & flaps have turned out looking almost exactly like yours. I guess I will figure out the drilling jig on my own for now.
I was surprised by just how much d*cking around I had to do with all the, cutting, gluing, sanding, fitting, swearing & repeating that has been done in the last 2 weeks.
Once I get this set of flaps done, I will start & document the left wing.
Thanx...
#172
ON, CANADA
Dangaras....glad that it's working out for you. Yes, it is a lot of work. I documented mine from the beginning, that way when I came to work on the second wing all I had to do is refer to my pictures and drawings. But I guess everyone has his own method.
Charles.
Charles.
#173
ON, CANADA
Charles,
the messing with the flaps &getting the flap leaging edge compound curves just right frustrated me the most. Imeaseured everything &measured again 3 or 4 times, built up the front edges separately, then sanded &then glued and still Ihad "rework".
Ithink Iwill make the flap LE out of a solid piece this time, sand &cut &sand until Iget it to fit under the wing TE perfectly &then cut the flaps apart. Then Ican cut the flaps down as necessary to put the ply endcaps on. Ithink documenting the second build and posting on RCcanada will be of more use to those crazy enough to follow along..
Thanx.
Thanx.
#174
ON, CANADA
ORIGINAL: Dangaras
Charles,
the messing with the flaps & getting the flap leaging edge compound curves just right frustrated me the most. I measeured everything & measured again 3 or 4 times, built up the front edges separately, then sanded & then glued and still I had ''rework''.
I think I will make the flap LE out of a solid piece this time, sand & cut & sand until I get it to fit under the wing TE perfectly & then cut the flaps apart. Then I can cut the flaps down as necessary to put the ply endcaps on. I think documenting the second build and posting on RCcanada will be of more use to those crazy enough to follow along..
Thanx.
Charles,
Thanx.
#175
ON, CANADA
Charles,
I agree, this is the best route.. The shaping in one piece then cutting. Ididn't have the thick balsa sheet when Istarted so Iused 1/4 strips and that was the mistake. Turned out ok and Iam going to stop with at the point where Iam ready to start mounting hinges on this wing and start the other one to get them both to the same point.
Once there, Iwill work the inter-web, flap pins, hinge positions, servo &push rod location &then covering &permanent mounting. Then I plan to put two retract servos in to drive each retract, the stock linkage is too finnicky if there is ever a rough landing.. Should be ready to fly for summer.
Lucky for me Ihave a spare wing to work on while my stock wing remains unchanged for flying until Iget this one completely finished.
Thanx for all the help with this.
