don smith p-47
My Feedback: (16)
don smith p-47
hey guy's i was about to get started on a zirolli 92 incher untill i found the don smith plans 122" but i've yet found what power it requires. i know it's going to cost alot more but i figure about the same amount of time so why not go all in on the big bird. will a q-100 be enough? thank's jeff.
RE: don smith p-47
Hi Jeff,
I would go for the Moki 215 or why not the new 250 just think of that sound
Cheers Graham.
WWW.TIGERMODELS.NET
Cheers Graham.
WWW.TIGERMODELS.NET
RE: don smith p-47
Hi Jeff,
Airworld USA are the main guys, what about the 400!!!!!! http://www.airworld-usa.com/gasoline.htm
Cheers Graham.
WWW.TIGERMODELS.NET
Cheers Graham.
WWW.TIGERMODELS.NET
RE: don smith p-47
WELL BAD NEWS FOR YOU ALL THE 215 OR 250 OR THE 400 WILL NOT FIT YOU WILL NEED TO DO A LOT OF MODS TOGET A RADIAL ON IT I KNOW THIS AS I AM BUILDING ONE AND I DO LOTS OF AW MOKI RADIALS IF YOU I SELL THEM AS WELL
JOHN
WWW.ERCAIRPLANEFACTORY.COM
JOHN
How could that be. The D. Smith cowl is 13" wide and 18+" top to bottom. Moki 215 or 250 diam. are only 11.22" The Moki 400 is 13.78" in diam. that would require some cowl mods. Thinking about the same kit with a Moki 250. What a sound.
JOHN
JOHN
Yea, CARF P47 was designed around the Moki 250 so the larger D. Smith P47 should be ok for the M 250. By the way Dino DiGorgio from Meister Scale is getting ready to release a new 122" P47 in about a month. He told me it is being engineered for the M215 or 250. The smaller Meister 102" P47 is only large enough for the M150.
[h=3][/h]
[h=3][/h]
