KMP F8-F Bearcat
#634
just sprayed today the repaired wing with that specially made standard blue color.The results are not what i expected! t'hat's not the same color
#640
Finally here's a flight video, flying in formation with my buddy's La-7
The F8F's climb ratio is phenomenal, and the Frise ailerons make rolls axial
https://www.youtube.com/watch?v=sCPI6-NUIuE
#646
Hello ,
I am buidling the bearcat and have an issue fixing the wing on the fuse .
Threre is a gap about 5mm almost all long .
I believe the problem is on the backseat of the fuselage holding the wing with the screws as there is no dihedral on the fuse ( see pic 20 on the manual )
it makes the wing going up on the rear and create a bad incidence .
Did you have the same issue already ? Do I need to sand the wing ?
Can someone tell me the right incidence needed between wings and stab ?
Thank you for your answers
Ger56
Ger56
#650
Hi
The photos are not very clear, as far as I can tell the saddle is following the airfoil
Could it be that the holes for the wing dowels have been drilled too low?
If that;s the case fill them up with matching dowel and re-drill
