Reload this Page >
Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
Old 12-19-2020, 05:12 PM
  #3351
ThunderBoat42
ThunderBoat42's Avatar
Keeping this thread alive. There are still kits popping up but I believe we will start seeing people picking up and doing rehabs.
Used Robards spokes wheel covers on both inside and out of when. Drilled hole for axle.
Ported scoop to air flow through rear half of fuse. Half a wooden train whistle epoxied in to give whine at certain speeds.
Since there seems to always be confusion on if gear is 85 or 90 degree. This one is 90 degree. 3.25” wheels will fit instead of the 3”
Biela 17” prop generates a ton of torque requiring slow throttle advance and a steady right rudder through climb out until flying speed is reached.
Old 12-20-2020, 06:21 AM
  #3352
jwalk2c
My Feedback: (47)
Thank you for posting this picture of the 90 degrees retracts. I have 4 TF GE kits, plus 4 rehab projects work in progress and waiting for my retirement if I can live long enough LOL.
I have often wondered about this, in fact, returned Robart 90 degrees for 85 degrees. . The TF instructions recommend 90 degrees, and seeing your photo they look fine.
Old 12-20-2020, 07:59 AM
  #3353
KaP2011
My Feedback: (17)
KaP2011's Avatar
The 90 degree retracts do make it a little more stable when turning on the ground because of the wider stance but it triggers my ocd. The 85 degree look better to me.
Old 12-20-2020, 12:57 PM
  #3354
ThunderBoat42
I’m doing same. Accumulating projects projects for retirement. Even plastic models for when I can’t get around good anymore. We have the COVID now though and it’s kicking our butts.
here is the 90 degree head on. Vs full scale. It’s undetectable in person in the spread and yes.... you are correct ... huge difference in ground handling.
most Are looking at the prop anyway. It does command attention.
The following 2 users liked this post by ThunderBoat42:
jeep36 (02-09-2021), KaP2011 (12-20-2020)
Old 02-05-2021, 04:39 PM
  #3355
TerryW
Hello,
I purchased off eBay trustingly a number of years ago a yellow box P-51 70's era, fouond the canopy cracked and broken. Does anyone know where you can get a replacement ? Perhaps someone might have an old canopy in their spare parts box they no longer want or need.
Thanks for your help.
Terry
Old 02-11-2021, 08:25 AM
  #3356
jeep36
Have you checked Fiberglass Specialties INC?
TerryW (02-11-2021)
Old 02-11-2021, 09:04 AM
  #3357
TerryW
Yes, and no they don't carry that item. I tried Dynamic Balsa as they carry some of the canopies but have not responded back as yet .
Thank you
Terry W
Old 02-11-2021, 03:48 PM
  #3358
jwalk2c
My Feedback: (47)
ParkFlyer Plastics has a good selection of canopies
War bird : Park Flyer Plastics, Official Website of ParkFlyer Plastics Hobby Accessories � Texas, USA
Topflight P-51 B
TerryW (02-11-2021)
Old 02-11-2021, 05:16 PM
  #3359
TerryW
Will check it out !!!
Thank you.
TW
Old 12-15-2022, 06:29 AM
  #3360
dawhale
My Feedback: (20)
I am assembling a 60 size TF p51 ARF. Considering the Robart electric retracts. How are they holding up?
Old 12-15-2022, 07:31 AM
  #3361
bladebender
Would like to find one for sale
Old 02-11-2023, 11:05 AM
  #3362
xtraflyr
Default Swap meet find!
Hey all,
Just picked up this TF Mustang with a brand new DLE 20,spring air retracts,with oleo struts,from local Swap meet,for $400 The plane has never flown!!
Drawn on panel lines
Old 02-14-2023, 08:40 AM
  #3363
FlyerInOKC
FlyerInOKC's Avatar
Nice buy!
Anyone looking for a Top Flite Warbird or cockpit kit I recommend checking here: https://planesgoneby.com
It's a one man shop but he is lowly adding to his kits and cockpit kits. Personally I'm saving my pennies and waiting for him to finish his Bonanza kit.
In the past year I cut a deal with a local flier for TF GE Spitfire, P-39 Cobra, and P-40E kits. I plan on purchasing a few cockpits from the above link.
Old 02-16-2023, 03:22 PM
  #3364
dawhale
My Feedback: (20)
I am assembling a 60 size Top Flite P51 ARF. Getting ready to install the stabilizer . Test fit the elevators. Found some twist so I attempted to apply a little bend in the elevator joiner wire. It broke. So I am looking for one. I know its a long shot. Let me know if you have one.
Thanks, Dale
Old 02-16-2023, 04:20 PM
  #3365
xtraflyr
Default Dle20 choke?
Hey everyone!
Anyone reining a DLE 20 and if yes,how are you running the choke? I was going to grind it off and use a steering arm from a nose gear steering. So dumb the way the choke are is.
Old 02-16-2023, 08:24 PM
  #3366
FlyerInOKC
FlyerInOKC's Avatar
For my scratch built Ryan SC-W project, I made one like it using piano wire, a piece of brass for the horn, two wheel collars. After assembly I soldered everything together. I ended up removing the pivots I didn't need them.
Thanks, Dale
Old 03-05-2024, 08:28 AM
  #3367
sr71hjason
Default Canopy
Anyone know where to get a replacement canopy? Mine warped somehow and is unusable. Thanks!
Old 03-05-2024, 08:38 AM
  #3368
FlyerInOKC
FlyerInOKC's Avatar
If the kit canopy will fit shoot these guys an email: https://planesgoneby.com
Or this guy in the UK: https://www.facebook.com/groups/8514...1552850339024/
If you need the Giant P-51D Arf try here: https://www.aero-accessories.com/topflite/index.html
Old 03-05-2024, 09:34 AM
  #3369
sr71hjason
Thanks for the help, I'll give them a try!
