Reload this Page >
TBM 93" Zero ARF Build
Old 11-09-2008, 11:43 PM
  #51
CHAWKJIM
CHAWKJIM's Avatar
Default RE: TBM 93" Zero ARF Build
Thank you , any help would be greatly appreciated. I would like to fly in a war bird meet this weekend , and I need to do a lot of test flying. I am also looking for a more detailed cockpit. One that has the stick and is painted I have the stock gauges that look really good however I would like to do a more detail if possible. Thanks for helping. I am going to need all the help I can get to be ready for the weekend.
Old 11-10-2008, 12:46 AM
  #52
F-15J_JSDF
F-15J_JSDF's Avatar
Bloody hell that was quick, I am impressed. So there was nothing that had to be changed? I read on the site all the time guys building ARF having problems with them and needing to change things to get the together. I have noticed there are a lot of guys on the site that start build and never finish them because of the problems.
If this TBM was so easy then I will inform the guys here when I get mine and let them see how fast it is to build.
What Servos are you using please.
CHAWKJIM さん
Can you make a Video of the maiden flight?
Old 11-10-2008, 09:42 PM
  #53
CHAWKJIM
CHAWKJIM's Avatar
Just finishing up the control rods and setting up the through s. I am not going to do the cockpit until I find the pilot. I should be test flying tomorrow. I will let you know how she fly's. Here is some photos with the canopy on and the cockpit that comes with it. There is a shot of the receiver.
ID:	1069800   Click image for larger version
ID:	1069801   Click image for larger version
Old 11-11-2008, 05:00 AM
  #54
F-15J_JSDF
F-15J_JSDF's Avatar
I really want to get one now.
Old 11-11-2008, 08:23 AM
  #55
CHAWKJIM
CHAWKJIM's Avatar
I will try . Its kind of hard to fly and vidio at the same time though. Ha Ha
Old 11-11-2008, 08:34 AM
  #56
CHAWKJIM
CHAWKJIM's Avatar
servo list
For the ailerons I am using JR 8411's
For the elivator I am using Hitec HS 5245MG
For the flaps I put JR 8711's as i just had 2 sitting around I will replace them with something later
For the rudder I used 1 JR8711 this is also controlling the wheel
For the air control valve hitec 81
for choke and throttle JR537
I made a ignition cut off with a switch and hitec 81
That all for now but I will put smoke in it later.
If anyone has any questions let me know. This new TBM model was very easy to assemble andI did not have to change anything. So I give this a 10 out of 10 on the build scale.
2 THUMBS UP FOR TBM ON THIS WON
Old 11-12-2008, 03:42 PM
  #57
Taildragger726
Taildragger726's Avatar
CHAWKJIM brought the TBM Zero over to our coveted, top secret flying site today for a maiden voyage. I was surprised that the airplane was assembled, minus the outer wing panels. It fits easly in the bed if CHAWKJIM's pick up truck. The center section with gear and flaps, was already bolted to the fuse. The outer wing panels plug into the center section, one servo conection per side and it is ready. The retention method is reallyy neat. The cannon and machine guns are attached to long pins that go through the spars and retainers.
The maiden went well, I'll let CHAWKJIM tell ya more. I even think we got some video.
TonyG
Old 11-12-2008, 10:38 PM
  #58
CHAWKJIM
CHAWKJIM's Avatar
I flew the maiden voyage. The flight was excellent 2 clicks down and 2 clicks right . The plane weighed 26 1/2 lbs without fuel. the engine has plenty of power as 90% of the flight was on half throttle. I only flew for about 4 to 5 minutes. This was just a shake down flight. We did get to video and here is the link. Hope you enjoy this as much as I did.
http://www.youtube.com/watch?v=KUy4mLNhhXo
Old 11-12-2008, 11:02 PM
  #59
LDM
My Feedback: (15)
Jim she looks rock steady , congratulations on the maiden !!!
I still did not hear back on the pilot from the hobby shop in Minn , I will be there on 11/21 if they have one I will pm you .
Lou
Old 11-12-2008, 11:34 PM
  #60
joe2011
cool vidio looks good i need one
see you in the am
Old 11-12-2008, 11:54 PM
  #61
F-15J_JSDF
F-15J_JSDF's Avatar
Jim Thanks for the Video Link, She is a nice bird.
Old 11-13-2008, 01:14 AM
  #62
CHAWKJIM
CHAWKJIM's Avatar
When I landed I was not using the flaps and she was still slow and easy. I am very happy with the purchase of the TBM zero. 1 week of building and I end up with one of the nicest flying, best looking plane I have ever had the pleasure of owning. There are no surprises with this kit. You get quality with this new Zero. If anyone has any questions let me know I will be more than happy to answer them. Tomorrow I fly again. I will try to use the flaps to see how they work I will let you know.Need to break in the new motor. Sounds like the perfect reason to fly .
Old 11-13-2008, 09:50 AM
  #63
msouers
Jim,
Was the white color hard to see in the sky and clouds? Neat looking plane!
Old 11-13-2008, 01:42 PM
  #64
Whistling Death
Whistling Death's Avatar
ORIGINAL: msouers
Jim,
Certainly not speaking for Jim but I have planes of both colors and they are hard for me to see. I have to keep them close because it gets scary when they get to far away.
I am putting together an H-9 P-51 150 and I have resigned myself to keep the bright stock colors so I don't lose it in the clouds.
Old 11-13-2008, 04:09 PM
  #65
msouers
Jim,
I really like your plane. Do you think that I could land it on 360' of asphalt runway? I have a Top Flight 80'' T34 Mentor that takes about 3/4 of the runway. Please give me your honest opinion. Thanks.
Mark
Old 11-13-2008, 04:46 PM
  #66
F-15J_JSDF
F-15J_JSDF's Avatar
You can always go ORANGE
ID:	1071516   Click image for larger version
ID:	1071517   Click image for larger version
ID:	1071518   Click image for larger version
Old 11-13-2008, 06:50 PM
  #67
CHAWKJIM
CHAWKJIM's Avatar
honestly I think it will land in a very short runway as I did not use any flaps and look at the video how stable and slow she is. 1st flight.
Old 11-13-2008, 06:54 PM
  #68
CHAWKJIM
CHAWKJIM's Avatar
I did not have any problem seeing the plane in this color. I never felt disoriented at any time it was easy for me to see. I will know more tomorrow if it isn't so windy. I will fly then.
Old 11-13-2008, 07:03 PM
  #69
F-15J_JSDF
F-15J_JSDF's Avatar
Think when I order mine the first thing I will do is re-paint it to look like the A6M5-K. Just looking on a Japanese RC Club Site and everyone that has Zeros are Green or White ... I like to be DIFFERENT so the A6M5-K colour scheme will be something different.
Old 11-13-2008, 07:30 PM
  #70
CHAWKJIM
CHAWKJIM's Avatar
What color is that ?
Old 11-13-2008, 08:56 PM
  #71
CHAWKJIM
CHAWKJIM's Avatar
is that an Orange?
Old 11-13-2008, 09:28 PM
  #72
F-15J_JSDF
F-15J_JSDF's Avatar
From what I have read they had a few colours ... Black, Camo, Orange, Yellowish brown ... I will get my wife to reseach more on Japanese sites as my reading of Kanji is not that good.
Old 11-13-2008, 10:09 PM
  #73
CHAWKJIM
CHAWKJIM's Avatar
when you decide on color check to see if they have exhaust. You would need the green from TBM for the exhaust. The white has no exhaust.
Old 11-14-2008, 12:32 AM
  #74
F-15J_JSDF
F-15J_JSDF's Avatar
No Zeros had exhausts out the sides until the A6M5 Type 0 Model 52 , before the they were clean lines but for two ports below the cowling
A6M2 ... as you can see no exhaust but for at the bottom of the cowling
A6M3 ... Clipped wing and no exhaust around the Cowling.
I think the WHITE TBM is based off the A6M2 to A6M4 and the Green TBM is based on the A6M5 ... the A6M5-K would have the 4 exhausts on each side but she was a twin seater, so need to have a look and see if it is possible to change a TBM to twin seater!
Old 11-14-2008, 02:19 PM
  #75
CHAWKJIM
CHAWKJIM's Avatar
Went flying today and messed with the flaps. Seems that 40% flaps you need a mix of down of 14 I don't know what the % is but the value on my JR 9303 was 14 down . The plane floats in so slow it was easy to land. You dont need a large runway at all. I will keep you posted as I figure out more.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
