Lado retracts, do the really exist?
#1951
Magnum RC,
Thank you very much for that great information; it is exactly the type of support one hopes to get on these forums. Can you tell me who Doug is that you refer to in your post?
Lars
Lars
#1952
My Feedback: (8)
All you have to do is to go to the beginning of this thread to find out who "Doug" is. He is the electronic inventor of the Lado retracts, he invented the entire mechanism, the casing, everything then messed up in it's marketing by screwing up his customers. He sold Lado to the French and left them holding the bag so to speak. The French engineers improved them a lot and brought new products in expansion. And for a while thru Magnum RC, Magnum RC in unison with the French, brought it back from the brink in the US market. Magnum RC wasn't making any money with them, and the French was losing too much in the export and support so they parted ways.. Magnum RC has some new offerings now if you want to look. Not saying the Lado's aren't good, they are. They are made in France, and they have successfully penetrated the European marketplace. They are popular on jets.
#1955
My Feedback: (13)
I have a pair of Lado's gathering dust. The board on one of them is fried. I bought them from Magnum RC is Sept., 2011. They are the Lado 85 degree(Narrow) Electric Retracts (RS333-85). Both have been drilled out to accept 5/16" struts (maybe 5mm). The pair had about 70 flights on them before the one started giving me trouble.
The good one seems solid and still seems to move OK.
If anyone wants them, send me a pm or email. I'll let them go for a twenty.
Brian
Brian
#1956
My Feedback: (13)
I got a hold of Century jet yesterday and am having a set of the actuators sent out to me to install for my Top Flight P-47 gear that are constantly leaking, I will report back to let every one how they are, I also got there controller which allows you to use a second battery with them.
if all goes well I will send a couple of sets off to CJ for a retro fit installation, the P-47 centurion gear is a direct drop in replacement for the air piston, the other gear I have need to be slightly adjusted to fit properly so I will most likely send them in for a free retrofit installation,I have a set for Top Flite FW190,and Top Flite P-40 there actuators were not really that pricey with the controller so if I like the first set I will most likely do the others .
#1958
Of course they can if they are willing to. It is just the shipping back and forth that kills you. Contact them, they are very agreeable to work with. They probably will update your unit to latest electronics as well if you have early versions.
#1959
Curious if the Lado can be modified to work with the CJ controller. Their retracts are nothing but a motor. They plug in with just two wires to the controller. The controller does the rest, even senses a stuck gear and stops it. Wondering, can the guts be pulled and a connector wired to the motor?
#1960
Well, the worst thing that can happen for this kind of experimentation is to take out the controller and or the motor and have to buy a new one. Everything in these electric retracts whether it is Lado or Century JET or E-flite and the list goes on, are electrically matched and engineered compatible. It would be an interesting experiement. If you decide to do it, be sure to let us know if you were successful.
#1961
My Feedback: (13)
a note about the LADO gear I have I use a NiCad 4.5v or a 4 cell NiMH battery and they have worked well all of the gear were purchased from Doug so I guess if they do die I will need to send them off to France bummer about Magnum not doing maint or selling these.
#1962
The CJ retracts use a small DC motor with 2 wires off it. Not much different than those you would get in a motorized model car kit. If the motor on the Lado is similar, then I dont see any reason for it not to work with the CJ controller. The CJ controller has a current cutoff so if the motors draw more than a set current it drops power to it. Best way to know for sure is to contact Bruce at CJ.
#1964
I ordered new Lado RS333-RB rotation gear. (60 size rotating gear). Arrived in about a month. They are exactly the same size as the original Lado rotators but the trunion appears to be steel and now has a 6mm rod intregal rod. Dropped right in where the old Lados were and all I had to do was drill on the bushing in the struts from 5mm to 6mm. They seem to work fine. No flights for a while with a foot of snow on the ground and another foot forecast. They would be better if they were 100 degree instead of 90, but I built the mount to give a forward rake so they will be ok. Installed in a VQ 60 size P-40.
#1965
My Feedback: (20)
RBean, when you say you drilled out the struts what brand are you talking about. A couple of months ago I bought two more pairs of 85 degree LADO's and struts. Struts looked to be good quality. Time will tell. They came with the 6mm pins.
I wish LADO would do 100 degree. I would buy two pair tomorrow. For the life of me I can not figure why they wont produce them. Guess they are doing well servicing another market.
#1968
I would guess that LADO would offer 100 degree rotators if they could come up with a reliable design. It appears that the rotating mechanism adds enough work to the system to increase the power needed to another level.
It could also be that developing a rotating mechanism that travels the extra amount is beyond their capability. R&D can be costly.
Only they know the answer, and for awhile now they've not been very talkative.
#1970
My Feedback: (20)
People I have been talking with are saying the Sierra 60 size rotating retract works good. On the down side is they weight #1. Might be a contender If they could put them on a diet.
I do not understand why LADO is the only one to produce a reliable electronic actuator.
#1971
My Feedback: (20)
#810RSE 100 deg Rotating Electric Retract
http://robart.com/products/810rse-10...ectric-retract
Who is going to be first?
#1973
http://robart.com/collections/retrac...t-control-unit
Dirk
#1974
You need also the Electric Retracts Control Unit.
Dirk
Dirk
#1975
My Feedback: (20)
If they work. $310 is not bad. I know you know this da Rock. LADO's are about $270 - $280 by the time they are shipped from France. Robart's are also 1/2" longer then LADO's. Could make the install problematic, main spar encroachment. I would still like to see LADO produce the 100 degree rotaters. Are you listening Christophe? I would order three sets tomorrow. I think I am a good customer. I need good reliable 100 degree rotaters.
Looks like Sierra is producing a good 100 degree rotater. I would convert them with LADO actuators if they wernt so expensive.
