Reload this Page >
World Models P-51 Mustang G.S. ( S1 - Ridge Runner )
Old 02-13-2009, 03:16 PM
snappa
Default RE: World Models P-51 Mustang G.S. ( S1 - Ridge Runner )
Well the retracts are finished, the supplied units are spring assist and boy you need that there is quite a load on the servos with this I used Hitec HS75 retract servos
Old 03-15-2009, 12:25 PM
c-130RCpilot
Could one of you World Giant Scale (GS) P-51 owners help me with a CG question? I'm just finishing up a World P-51 GS and the CG seems way off. The instructions indicate 6.9" or 175 mm behind the leading edge "where the wing meets the fusealage." My problem is as-built, my plane is currently at about 1 3/4 inches ahead of that point! I've never seen a nose-heavy warbird like this and I'm a little stumpted. I've built the plane with an inverted Moki 1.80 (yes a little big for what the plane is spected for) with an aftermarket Pitts style muffeler on a 20x10 plastic prop. All the servos, fuel tank, etc, are in their correct locations as specd in the instructions. In the nose I've included an in-line fueler valve and a remote Ni-starter connection so I can connect the glow battery on the top of the cowl. So, I don't think I've added any appreacble weight.
I would appreciate any feedback on the actual CG's from any of you guys who are successfully flying the World GS P-51.
Eric
Old 03-15-2009, 04:30 PM
rc34074
Mine is balanced per the dimensions you list - it flies very well there. I use less travel on the elevator than they recommend. For landing i put expo on the elevator on all my warbirds - from -20% to -35% depending on the plane. since I have futaba radios the expo is negative. the expo makes the elevator less touchy on landing.
Ed
Old 03-15-2009, 06:16 PM
c-130RCpilot
Thanks for the input rc34074! Did you find it necessary to add a lot of tail weight to achieve the correct balance?
Eric
ORIGINAL: rc34074
Ed
Old 04-09-2009, 02:29 AM
snappa
motor in now
ID:	1176362   Click image for larger version
ID:	1176363   Click image for larger version
ID:	1176364   Click image for larger version
ID:	1176365   Click image for larger version
ID:	1176366   Click image for larger version
ID:	1176367   Click image for larger version
ID:	1176368   Click image for larger version
ID:	1176370   Click image for larger version
ID:	1176371   Click image for larger version
ID:	1176372   Click image for larger version
Old 04-09-2009, 02:42 AM
  #31
snappa
This motor is a ASP 180 so is quite a decent size, its well hidden under the very nice 3 part canopy... It has a set of vents in the front of the motor and air can exit out around the rocker cover however I am considering using my tools to remove the fibreglass from the inside of the exaust stacks to give more air flow... what do you think? The rudder and elevator control wires are installed and work nice, I have included a little ackerman in the controls as well..
Old 04-09-2009, 02:44 AM
  #32
snappa
This plane is I guess a very plain Jane model but to be honest very very well made
Old 06-07-2009, 10:56 PM
  #33
A6TEXAN
wondering how well the plane flys with the 180 four stroke ? i was thinking of putting the same engine in mine. thanks.
Old 07-16-2009, 07:52 AM
  #34
mike early
mike early's Avatar
this thread died too young!
Old 07-16-2009, 06:48 PM
  #35
JEFFHINES73
JEFFHINES73's Avatar
I agree
Old 07-16-2009, 10:19 PM
  #36
rc34074
I have my world gs miss america ready to fly but haven't flown it yet this year. I'm planning to fly it some as is with the stock super tiger 2300 I have in it, and then I will change the 2300 carb to a walbro wt499 carb, which will let me invert the 2300 and still run it on glow fuel. I have already tested the walbro on the 2300 and it works great on this engine with the same 10 % Omega fuel I usually run in the 2300 now.
once I have all this sorted out then I will strip the covering and redo it as a WW2 version. I would like to find a new set of the cowls for this plane - anyone have a set they would sell me that is not cut out yet?
Ed
Old 12-18-2009, 02:48 AM
  #37
Tasman!!!
Hi Mike
I just purchased a World Models P-51 G.S. Double Trouble Colour Scheme, I hope to get this thread up and running again.
I will post some Photos/Questions etc over the coming weeks.
Regards
Michael.
Old 01-01-2010, 08:50 PM
  #38
j301
My Feedback: (12)
j301's Avatar
Anyone know if a SuperTigre G-3250 is adequate for this plane? Has anyone had any experience with this engine?
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
