Reload this Page >
Knowledge Quiz for Warbird wiz
Old 02-11-2012, 01:10 PM
  #6501
Ernie P.
Default RE: Knowledge Quiz for Warbird wiz
Looking for a winner. THanks; Ernie P.
What warbird do I describe?
Clues:
(1) It served both Army and Navy units.
(2) The design was based upon careful study of an enemy fighter.
(3) Many of the design features of the enemy aircraft were carried over into this design.
(4) The fuselage was welded steel tubing.
(5) The wings were fabric on a wooden frame.
Old 02-11-2012, 01:34 PM
  #6502
metaldriver
I am going to say the curtiss P-1/F6C hawks which evolved into the P-6 and F11C respectively
Old 02-11-2012, 03:40 PM
  #6503
Ernie P.
ORIGINAL: metaldriver
Sorry, no. But you aren't as far away as you might imagine. Maybe this will help. Thanks; Ernie P.
Clues:
(6) The Navy used the plane for carrier operations.
Old 02-11-2012, 04:15 PM
  #6504
a65l
My Feedback: (17)
a65l's Avatar
The Boeing F4b / P-12
Old 02-11-2012, 05:07 PM
  #6505
Ernie P.
ORIGINAL: a65l
No Sir; but you aren't far off the mark. Thanks; Ernie P.
Clues:
Old 02-11-2012, 05:19 PM
  #6506
Mein Duff
Mein Duff's Avatar
Grumman F3F?
Don't think they copied anybodies design though....
Old 02-11-2012, 06:48 PM
  #6507
Ernie P.
ORIGINAL: Mein Duff
Grumman F3F?
No, Sorry. But keep trying. Thanks; Ernie P.
Clues:
(7) It was the first successful fighter design by the manufacturer, and had much to do with the manufacturer becoming the huge concern it became.
Old 02-11-2012, 06:50 PM
  #6508
Ernie P.
ORIGINAL: Mein Duff
Grumman F3F?
Clues:
Old 02-11-2012, 08:38 PM
  #6509
Ernie P.
Moving right along. Thanks; Ernie P.
Clues:
(8) A trainer version was produced.
Old 02-12-2012, 04:35 AM
  #6510
Ernie P.
And yet another clue. Thanks; Ernie P.
Clues:
(9) The first aircraft delivered to the Navy were not equipped with arrestor hooks, so were utilized by the Marine Corps.
Old 02-12-2012, 05:50 AM
  #6511
metaldriver
vought ve-7
Old 02-12-2012, 07:09 AM
  #6512
Ernie P.
vought ve-7
Sorry, but no. Maybe this will help. Thanks; Ernie P.
Clues:
(10) One version supported the Marines in China.
Old 02-12-2012, 08:35 AM
  #6513
Ernie P.
A big clue. Thanks; Ernie P.
Clues:
(11) The copied plane was a Fokker D. VII
Old 02-12-2012, 10:55 AM
  #6514
Ernie P.
As the hours dwindle, the clues become more obvious. Thanks; Ernie P.
Clues:
(12) The subject aircraft was originally designed to use a Wright-Hispano engine, but was redesigned to use a Curtiss liquid cooled engine.
Old 02-12-2012, 11:23 AM
  #6515
nutz4planes
Dehavilland DH-4 redesignated 02B for Marine and Navy service?
Old 02-12-2012, 02:20 PM
  #6516
Ernie P.
ORIGINAL: nutz4planes
Sorry, nutz4planes. Good guess, but not the one I had in mind. This should do it for you. Thanks; Ernie P.
Clues:
(13) The company which produced the aircraft was Boeing.
Old 02-12-2012, 03:05 PM
  #6517
JohnnyS
Boeing Model 15?
Old 02-12-2012, 04:14 PM
  #6518
Ernie P.
ORIGINAL: JohnnyS
Boeing Model 15?
Bingo!! Sir; you have the answer and you are next in line to ask a question. Make it a good one, Sir. Thanks; Ernie P.
Clues:
(14) This Boeing Model was produced after their 14th Model and before their 16th Model.
Answer: The Boeing Model 15
The Boeing Model 15 was a United States open-cockpit biplane single-seat fighter aircraft of the 1920s, manufactured by the Boeing company. The Model 15 saw service with the United States Army Air Service (as the PW-9 series) and with the United States Navy as a carrier-based fighter (as the FB series).
The design of the Model 15 was based on studies of the Fokker D.VII, 142 of which were brought back to the U.S. for evaluation as part of the Armistice Agreement ending World War I. Many of the features were similar. The Model 15 had a fuselage of welded steel tubing braced with piano wire, while the tapered single bay wings were fabric on a wooden frame, with spruce and mahogany wing spars and three-ply wood ribs. Wing struts were changed from the normal wood used in Boeing designs to streamlined steel tubes. The landing gear had a straight axle, streamlined into a small 16 in (410 mm) chord wing.
The original engine was a 300 hp (220 kW) Wright-Hispano, but when the 435 hp (324 kW) liquid-cooled Curtiss D-12 became available the aircraft was redesigned, moving the radiator from the nose to a "tunnel" under the engine. Along with some other minor design changes to the wings, the design was finalized on January 10, 1922.
The Army expressed interest in the new design, and agreed to provide armament, powerplants, and test the aircraft, while leaving Boeing the rights to the aircraft and design. The contract was signed on April 4, 1923 and the first prototype, designated XPW-9 for "Experimental Pursuit, Water-cooled engine", flew on June 2, 1923. The XPW-9 competed with the Curtiss Model 33 for contracts for a pursuit aircraft to replace the Thomas-Morse MB-3A in the United States Army Air Service.
Ultimately, both models were accepted; the Curtiss aircraft was designated PW-8 and the Model 15 PW-9. The Air Service preferred the PW-9, which outperformed the PW-8 in all performance aspects except speed, and was built on a more rugged and easier to maintain design, ordering 113 aircraft (only 25 PW-8s were procured). A naval version was also developed, designated FB, and 42 aircraft produced.
Deliveries of the first 25 PW-9s began on October 30, 1925. Boeing delivered a total of 113 PW-9s of all variants including prototypes to the United States Army Air Corps between 1925 and February 1931. Virtually all PW-9s served with overseas units, in Hawaii with the 5th Composite Group at Luke Field and later the 18th Pursuit Group at Wheeler Field, and in the Philippines with the 4th Composite Group at Clark Field, Luzon. PW-9s equipped the 3rd, 6th, and 19th Pursuit Squadrons between 1925 and 1931.
The FB-1, of which the Navy ordered 16 but received only 10 between December 1 and 22, 1924, was not modified for naval operations (for instance, no arresting hook), and was assigned to Marine Corps squadrons VF-1M, VF-2M, and VF-3M, being deployed to China in support of the Marine Expeditionary Force. Two additional planes—designated FB-2—were altered to operate on the carrier Langley with the addition of arresting gear and a straight-across axle for the landing gear. These went into service with VF-2 in December 1925. Generally satisfactory results led to an order for 27 FB-5s, which became the Navy's first fighters intended specifically for carrier operation. They were upgraded to 525 hp Packard 2A-1500 engines, and sported a row of hooks on the bottom of the axle, used to guide the plane via cables on the deck. The FB-5 first flew October 7, 1926 and was delivered to the Navy beginning in the following January, carried on barges in Puget Sound from Boeing's factory to Langley anchored in Seattle's harbor. Hoisted aboard, their first official flights were from the carrier's deck.
Old 02-12-2012, 04:15 PM
  #6519
Ernie P.
ORIGINAL: Ernie P.
ORIGINAL: JohnnyS
Boeing Model 15?
Bingo!! JohnnyS; you have the answer and you are next in line to ask a question. Make it a good one, Sir. Thanks; Ernie P.
Clues:
The original engine was a 300 hp (220 kW) Wright-Hispano, but when the 435 hp (324 kW) liquid-cooled Curtiss D-12 became available the aircraft was redesigned, moving the radiator from the nose to a ''tunnel'' under the engine. Along with some other minor design changes to the wings, the design was finalized on January 10, 1922.
The Army expressed interest in the new design, and agreed to provide armament, powerplants, and test the aircraft, while leaving Boeing the rights to the aircraft and design. The contract was signed on April 4, 1923 and the first prototype, designated XPW-9 for ''Experimental Pursuit, Water-cooled engine'', flew on June 2, 1923. The XPW-9 competed with the Curtiss Model 33 for contracts for a pursuit aircraft to replace the Thomas-Morse MB-3A in the United States Army Air Service.
Old 02-13-2012, 10:28 PM
  #6520
JohnnyS
Ernie P.: Thanks!
Clues:
1. It was a twin engine all-weather interceptor that served with NORAD.
2. It was reported to be the first straight-winged jet aircraft to achieve controlled supersonic flight.
Old 02-14-2012, 08:56 AM
  #6521
I-NAV
I-NAV's Avatar
I'm in Thailand for work and ran across these airframe parts at an Army / Navy store. Can anyone ID what aircraft they are from?
ID:	1726936   Click image for larger version
ID:	1726937   Click image for larger version
Old 02-16-2012, 07:29 AM
  #6522
perttime
perttime's Avatar
ORIGINAL: JohnnyS
Clues:
It's been a while with no posts...
I bet it is something Canadian.
Old 02-16-2012, 07:31 AM
  #6523
perttime
perttime's Avatar
ooppssss ... double post.
I'm sure I didn't click the button twice but there was some sort of a hangup.
Old 02-16-2012, 10:26 AM
  #6524
MajorTomski
MajorTomski's Avatar
Sorry I haven't been posting much the site has been running soo slooowly for me I sort of checked out for a while
the answer to the question would be the AVRO CF100:
Main article: Avro Canada CF-100 Canuck
In 1946, A.V. Roe Canada's next design, the Avro XC-100, Canada's first jet fighter, started at the end of the era of propeller-driven aircraft and the beginning of the jet age.[2] Although the design of the large, jet-powered all-weather interceptor, renamed the CF-100 Canuck, was largely complete by the next year, the factory was not tooled for production until late 1948 due to ongoing repair and maintenance contracts. The CF-100 would have a long gestation period before finally entering RCAF service in 1952, initially with the Mk 2 and Mk 3 variants. The CF-100 Canuck operated under NORAD to protect airspace from Soviet threats such as nuclear-armed bombers during all weather and day/night conditions. Although not designed for speeds over Mach 0.85, it was taken supersonic during a dive by test pilot Janusz Żurakowski in December, 1952.[8]
A small number of CF-100s served with the RCAF until 1981 in reconnaissance, training and electronic warfare (ECM) roles.[2] In its lifetime, a total of 692 CF-100s of different variants, including 53 aircraft for the Belgian Air Force, were produced.
Old 02-17-2012, 06:52 AM
  #6525
Ernie P.
ORIGINAL: MajorTomski
MajorTomski; JohnnyS hasn't been on this site for more than three days. Your answer appears to be correct. Rather than stopping the wheels, why don't you assume your answer is the one he wanted and move forward with your question? Thanks; Ernie P.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
