Knowledge Quiz for Warbird wiz
Morning clue. Thanks; Ernie P.
What warbird do I describe?
1. This aircraft was developed from a very popular and successful earlier model from the same manufacturer.
2. Our subject aircraft had some issues, chief among them a trouble prone engine that required a lot of maintenance.
3. It also had a rather fragile landing gear arrangement.
4. Although that was a result of poor or improper hardening of the metal used.
5. But it was definitely, when properly maintained, capable of competing on equal terms with any aircraft it faced in combat.
6. It is generally considered to be the best of its type fielded by its air force.
7. Ignoring prototypes, aircraft only available in very small numbers and such, it was definitely a star performer during the last couple of years of its war.
8. It was very fast; faster than the main types fielded by its opponents.
9. And it was heavily armed.
10. It was very maneuverable.
11. With a good rate of climb.
12. And a high ceiling.
13. But the aircraft’s performance was often hamstrung by manufacturing defects, difficulty in obtaining quality fuel and inexperienced pilots.
14. Its main asset was its very powerful, although complicated, engine.
And not the typhoon; but you do earn a bonus clue. Please try again; you'll get it! Thanks; Ernie P.
15. Our subject aircraft’s design began as its predecessor was being fielded.
Evening clue. Thanks; Ernie P.
16. The predecessor was very successful; with several thousand being produced.
17. But it did have some serious weaknesses; and these were addressed in our subject aircraft’s design.
Afternoon clue. Thanks; Ernie P.
18. Our subject aircraft added firepower, added armor and increased the rate of climb.
An evening clue. Perhaps a bit early, but perhaps welcome for all that. Thanks; Ernie P.
19. It also added self-sealing wing tanks and armor for the main fuel tank.
20. It also added an armored canopy and additional protection for the pilot.
21. The key to everything was a new air cooled radial engine; featuring methanol/water injection for the supercharger.
22. Later tests of captured aircraft indicated the subject aircraft, with high octane fuel, could reach speeds of over 400 MPH in level flight.
Okay, it's starting to sound Japanese but, if it was only a 400MPH aircraft, that was slower than the Corsair, later Spitfires, the "Merlin" Mustang(Allison powered versions, for the most part weren't able to hit 400 except in a dive), Thunderbolt, Typhoon and Tempest(among others) when they first appeared in combat
Sir; I can only repeat what is written. And I did write "Later tests of captured aircraft indicated the subject aircraft, with high octane fuel, could reach speeds of over 400 MPH in level flight." But I will award a bonus clue for your analysis. Thanks; Ernie P.
23. The landing speed was higher than its predecessor, which caused problems for some pilots; particularly those with less than adequate training.
Morning and afternoon clues. Thanks; Ernie P.
24. Although its performance at higher altitudes was considered to be marginal, its performance at lower and medium altitudes made it a very dangerous aircraft.
25. Our subject aircraft was a fighter.
26. Single seat.
26. Single seat.
Neither the Kawasaki Ki-100 or the N1K2-J Shiden-Kai. But you two earn two bonus clues for your efforts. Thanks; Ernie P.
26. Single seat.
27. Single engine.
28. Low wing monoplane.
26. Single seat.
27. Single engine.
A late night clue: Total production of the the Kawasaki Ki-100 or the N1K2-J Shiden-Kai was around 1,200. Our subject aircraft production was roughly three (3) times that number. Thanks; Ernie P.
26. Single seat.
27. Single engine.
29. Armament varied; either a combination of two machine guns and two cannons, or four cannons.
26. Single seat.
27. Single engine.
Afternoon clue. Note: From this point forward, clues will be mostly details (length, width, range, etc., or rather revealing in nature. Thanks; Ernie P.
26. Single seat.
27. Single engine.
30. It could also carry a couple of 500 lb. plus bombs.
26. Single seat.
27. Single engine.
26. Single seat.
27. Single engine.
31. And could be fitted with drop tanks.
26. Single seat.
27. Single engine.
26. Single seat.
27. Single engine.
32. The engine produced over 2,000 HP at sea level.
26. Single seat.
27. Single engine.
26. Single seat.
27. Single engine.
33. Length was just over 32-1/2 feet.
26. Single seat.
27. Single engine.
