Reload this Page >
Knowledge Quiz for Warbird wiz
Old 02-17-2021, 10:44 AM
  #19501
Ernie P.
Morning and afternoon clues. Thanks; Ernie P.
What warbird do I describe?
1. This aircraft was the first of its type to enter service.
2. And the first of its type to be used in actual combat.
3. It was built in three different countries.
4. It was developed from a single pre-war, unsuccessful, prototype.
5. Although the prototype aircraft crashed very early on, it was considered to be worth further development.
6. And that further development led to our subject aircraft.
7. It had a rather short service life, little more than a year of combat.
8. But its successful deployment started a flood of aircraft designed for the same purpose.
9. Aircraft which quickly rendered our subject aircraft obsolescent.
10. Which did not, unfortunately, result in its withdrawal from active service in combat.
11. As a result, our subject aircraft is mostly remembered as being little more than a target for enemy aircraft for much of its service life.
12. But the truth is that our subject aircraft was still a dangerous opponent when properly handled and utilized.
13. As more than one enemy pilot, including some very well known, learned.
14. Very early on, it was discovered the guns intended to be used were going to be a problem.
15. So, they were replaced with lighter and more dependable guns.
16. Its combat debut was less than stellar; as its gun jammed and secondary armament had to be employed.
17. Which resulted in a “probable” kill.
18. Less than a month later, the same crew, flying a different aircraft of the same type, was forced to land behind enemy lines.
19. The plane fell into enemy hands and the crew was captured.
20. Initially, our subject aircraft was provided to, and utilized by, different units in small numbers.
21. But very quickly, as larger numbers became available, full squadrons were equipped with the aircraft.
22. Within a year, it was outclassed by enemy aircraft; and was soon withdrawn from combat and used for training purposes. Note: Personally, I DO NOT concur with the written date of withdrawal. I think this aircraft was in service far longer than a year, possibly two, perhaps nearly three. More later. EP
Old 02-17-2021, 06:09 PM
  #19502
Ernie P.
Evening clue. Thanks; Ernie P.
23. The license built engines that powered our subject aircraft were often not up to the quality of the originals; which caused some problems.
Old 02-18-2021, 04:32 AM
  #19503
Ernie P.
Morning clue. Thanks; Ernie P.
24. Inadequate speed and rate of climb were further problems; making the plane inadequate for the role for which it was designed.
Old 02-18-2021, 11:34 AM
  #19504
Ernie P.
Afternoon clue. Thanks; Ernie P.
25. And some of the features of the aircraft, including its overall configuration, proved to be pretty much dead ends.
Old 02-18-2021, 04:03 PM
  #19505
Ernie P.
26. In the end, the combination of all these factors doomed our subject aircraft to a rather short active service life.
Old 02-19-2021, 09:45 AM
  #19506
Ernie P.
27. In fact, only one pilot achieved “ace” status in this aircraft.
28. And one observer.
Old 02-19-2021, 02:52 PM
  #19507
Ernie P.
29. A slightly later aircraft, with the same general layout and appearance, had better performance.
Old 02-20-2021, 06:00 AM
  #19508
Ernie P.
30. Which resulted in the later aircraft having a longer service life.
Old 02-20-2021, 09:06 PM
  #19509
Ernie P.
Sorry, guys; I've been busy. Afternoon and evening clues. Thanks; Ernie P.
31. And which caused a lot of confusion between the two types.
32. Because the layout and appearance of the two planes were very similar.
Old 02-21-2021, 08:41 AM
  #19510
Ernie P.
33. The later aircraft was considerably heavier.
Old 02-21-2021, 01:19 PM
  #19511
Ernie P.
An evening clue. Thanks; Ernie P.
34. But it also had more than 50% more power.
Old 02-22-2021, 05:01 AM
  #19512
Ernie P.
35. And a stationary inline engine that was more dependable.
Old 02-22-2021, 10:34 AM
  #19513
Ernie P.
36. Our subject aircraft had two crew members.
Old 02-22-2021, 02:37 PM
  #19514
Ernie P.
37. And two wings.
Old 02-23-2021, 07:17 AM
  #19515
Ernie P.
37. And two wings.
38. And, typically, one machine gun.
Old 02-23-2021, 08:41 AM
  #19516
Ernie P.
37. And two wings.
39. After the debut of our subject aircraft, enemy aviators typically referred to any aircraft of this type as being one of our subject aircraft.
Old 02-23-2021, 10:41 PM
  #19517
Ernie P.
37. And two wings.
40. Which would prove to be its most lasting legacy.
Old 02-24-2021, 01:01 PM
  #19518
Ernie P.
37. And two wings.
41. Our subject aircraft actually first flew before its war began.
Old 02-24-2021, 04:17 PM
  #19519
Top_Gunn
I can't find much about this airplane, so I really have no idea whether it fits all the clues, but I'll toss the name out: B.E.2?
Old 02-24-2021, 08:01 PM
  #19520
Ernie P.
Not the B.E.2, Al; but I will award a bonus clue in addition to the evening clue. You're thinking in the right direction, though. But, our subject aircraft was the first of its type. Thanks; Ernie P.
17. Which resulted in a probable kill.
27. In fact, only one pilot achieved ace status in this aircraft.
37. And two wings.
42. Although it didnt reach the field for a few months.
43. More than 200 were produced, which was a pretty respectable number for its day.
Old Yesterday, 06:23 AM
  #19521
Ernie P.
37. And two wings.
42. Although it didn’t reach the field for a few months.
44. It was powered by a single engine.
Old Yesterday, 09:33 AM
  #19522
Ernie P.
37. And two wings.
45. A single engine of rotary design.
Old Yesterday, 08:53 PM
  #19523
Ernie P.
37. And two wings.
46. Supposedly producing 100 hp; although this was an optimistic figure, most of the time.
Old Today, 07:26 AM
  #19524
Ernie P.
37. And two wings.
47. Its forward firing gun was a big advantage, although the early gun mounts proved problematic. But those issues were soon cleared up with new gun mounts; much of the work being accomplished by field modifications.
Old Today, 10:47 AM
  #19525
Ernie P.
37. And two wings.
48. Several versions were produced, although almost all aircraft produced were of one version.
