Reload this Page >
ESM Storch Build...
ESM Storch Build...
Old 07-29-2010, 04:59 PM
  #76
fockewulf37
My Feedback: (102)
Default RE: ESM Storch Build...
I also have my engine mounted. I am using an Eflight 110 nad I may change out of an Eflite 160. Still deciding. Anyway i made a wood standof and it turned out pretty good.
ID:	1475172   Click image for larger version
ID:	1475173   Click image for larger version
Old 07-29-2010, 09:02 PM
  #77
fockewulf37
My Feedback: (102)
Well I started working on the hinges for the alierons and flaps. I am truly amazed. I would have hated to be the guy jiging up this wing and making all of these slots. All the hinges fit perfectly into the wing and then into the control surfaces. You had to make each hinge. the hinge floats on a piece of threaded brass. I did have to drill the holes in each hinge to accept the brass tube but that was easy. I differed from the manual i made each hinge and then inserted them into the wing and made sure they were all the same depth. Before I inserted them into the wing i took a dremel tool and roughed up the end to let the glue get a better grip... Once the hinge was in place i took thin CA and wicked a good amount in around the base of each side of the hinge and then hit it with a little kicker. those will never come out. Once all the hinges were in the wing I then glued the control surfaces in...It was easy but took a little time.
I could just imagine trying to build this thing from scratch....anyway here are the pic's...
Ty
ID:	1475373   Click image for larger version
ID:	1475374   Click image for larger version
ID:	1475375   Click image for larger version
ID:	1475376   Click image for larger version
ID:	1475377   Click image for larger version
ID:	1475378   Click image for larger version
ID:	1475379   Click image for larger version
Old 08-13-2010, 08:26 AM
  #78
fockewulf37
My Feedback: (102)
I have not forgotten the Storch. I have been doing a little work at the time. I have evrything hinged and i was able to install the struts onto the wing. It was all pretty stright forward. Getting ready to install the tail wheel so I can start putting servos in place....
Ty
ID:	1483288   Click image for larger version
ID:	1483289   Click image for larger version
Old 11-15-2010, 06:42 PM
  #79
vallawyer
It does not fly, but it makes a very prety display model.
Old 11-15-2010, 10:10 PM
  #80
mobyal
Did you ever get it finished and try to fly it, or just say to hell w/ it and hang it from the ceiling?
Old 06-08-2011, 06:02 AM
  #81
RZorker
I've been following this thread for some time and think the ESM Storch is a beautiful airplane. I know it has been discontinued but does anyone know where I might be able to find one? Any help would be appreciated.
Old 06-08-2011, 06:55 AM
  #82
Experten109/40
My Feedback: (-1)
Experten109/40's Avatar
ORIGINAL: vallawyer
I was witness to one of these crashing on the maiden flight last week. The pilot was very experienced, and this should have been a very easy plane to fly.
There was a serious problem with lateral control, the plane was not flyable. It may be the slats or it may be the ailerons and the way they are hinged, I do not know, but Ido know the guy had a seriousl problem flying it and it was wiped out on the first fligth.
give ur head a shake. you were talking about this flight... : http://www.youtube.com/watch?v=6ShpGbLlgP4
firstly, see how they ' tuned ' the motor.. laughable, shouldn't have used it that way. secondly, its way to tail
heavy. a novice pilot would have picked up on that... nevermind an 'experienced' pilot. thatStorch was almost
doomed from the getgo.
Old 06-08-2011, 07:37 AM
  #83
TA152
I have flown an Esm Storch this weekend, and have some mixed feelings about it[] It's heavy (9Kg) and the landindgear is very soft. When the plane rolls you will get a toe out, and it needs a lot of speed to lift. It's a handful in the air, but lovely to land [I don't feel it so Storchish in the air.[]
Old 06-08-2011, 07:54 AM
  #84
wingspar
I watched the video and would have to agree with Expert. Looks very tail heavy. When it goes into one of its first turn it almost stands vertically on it's nose.
Dave
Old 06-08-2011, 10:39 AM
  #85
mobyal
As nearly as I can tell that "experienced" pilot never so much as touched the rudder.
Old 06-08-2011, 11:36 AM
  #86
TA152
The Storch needs a lot of rudder when flying Here is the one I flew.
ID:	1620706   Click image for larger version
Old 09-17-2011, 04:42 AM
  #87
Loopman
My Feedback: (195)
The plane flies great with one major mod, the slats in their stock position are too far forward of the wing leading edge and as such will act as "turbulators" in essence destroying the lift of the main wing. However if you reduce the distance between the WLE and slat TE by half of the stock position the plane flies beautifully. I must stress though that the CG is absolutely wrong on the plans and you should err on the side of being nose heavy. I flew mine on a SAITO 1.80 with a Higley Heavy hub installed and the flight battery as far forward as you can get it and I still had to add several ounces of sheet lead to get the CG right.
Happy Flying!
Loopman
Old 07-21-2012, 09:03 AM
  #88
kwik
kwik's Avatar
ESM Storch flying;
It is a little heavy, so it cannot land as slow as the real one ( size-wise) but if CG is correct, you can fly it;
http://www.youtube.com/watch?v=ZWhru...ature=youtu.be
Old 07-21-2012, 12:00 PM
  #89
glazier808
glazier808's Avatar
see it does fly!
and still manages to look great!
Casey
Old 07-21-2012, 12:55 PM
  #90
kwik
kwik's Avatar
ORIGINAL: glazier808
see it does fly!
Casey
Yes, but I am awaiting Vallawyers comment....
Old 07-21-2012, 03:03 PM
  #91
glazier808
glazier808's Avatar
you KNOW he will have one...
lol
Casey
Old 07-22-2012, 12:23 AM
  #92
a65l
My Feedback: (17)
a65l's Avatar
Glad to see this thread is still picking up some action. Thanks to work, I haven't been able to finish mine yet, but hopefully when I return from this trip it will fly. At last.
Old 05-11-2015, 01:29 AM
  #93
w1nd6urfa
w1nd6urfa's Avatar
Evil Merlin, Ty, CK1, a65l et al,
Bumping up an old thread I know, did you ever finish and fly your Storches?
I got one and plan to mod it until its flyable, I read/copied all the useful info and tips you posted if there's anything else please post
My build log: http://www.rcuniverse.com/forum/rc-w...l#post12036632
Old 05-12-2015, 03:30 AM
  #94
a65l
My Feedback: (17)
a65l's Avatar
Sold mine to another club member. I think he sold it to someone else... haven't seen it at the field yet
Old 05-17-2015, 06:31 PM
  #95
CK1
My Feedback: (60)
CK1's Avatar
I did get mine to fly fairly well and then sold it. It did not fly like I felt a Storch should fly. STOL characteristics were non existent. The plane required a great deal fine tuning to the leading edge slats and modification the landing gear to just get normal flight out of it . even after alot of work to lighten the plane it still was about 4 lbs heavier than it should have been . The Idea of a Storch appealed to me as I have built a couple of the Dennis Bryant 1/6 scale Storchs but this plane can not be compared to the Dennis Bryant (which does actually fly like a Storch should). The best input I could give anyone trying to improve this plane is to strip it and lighten it anywhere you can safely remove weight . Take your time setting the LE slats , they will help if set right and hurt if set wrong. You should have about a 1/2 to 9/16 " gap between the slat LE and wing leading edge with about an 3/16 gap between the trailing edge of the slat and the wing and the leading edge lower lip of the slat should be about an 1/8 " above the lower lip of the wing leading edge . also set about 4 degrees washout at the wing tips.
Old 05-17-2015, 07:18 PM
  #96
w1nd6urfa
w1nd6urfa's Avatar
CK1
Thanks for the input, I agree the ESM ARF is overbuilt and does feel heavier than it should. Do you remember the final weight of your Storch and did you add balast?
My plan is to move servos and everything I can forward of the CG and avoid adding dead weight at all cost. If still heavy I will take off balsa sheeting aft of the CG
Re. slats as you see in my build I copy the Svenson and Severin plans for correct dimensions and offset (I don't have the Bryant plans)
Old 05-18-2015, 04:00 PM
  #97
CK1
My Feedback: (60)
CK1's Avatar
If my memory serves me correctly I think it weighed a little over 14 .5 pounds. I know that I had to add some ballast but not as much a some I have read about probably 5 or 6 oz. . I did move the engine as far forward as the mounts and the cowl would allow. This reduce the need for ballast dramatically and improved tracking on the ground and in the air. I also did quite a bit of work on programming of the flaps and ailerons for a crow function which further improved flight characteristics
Old 05-18-2015, 07:27 PM
  #98
w1nd6urfa
w1nd6urfa's Avatar
Under 15 lbs is my target weight, seems possible with servos forward and an MVVS 26 for power.
Thanks for the useful info about the crow mix, did you have that on all the time or only activating with flaps down?
Old 05-19-2015, 05:04 AM
  #99
CK1
My Feedback: (60)
CK1's Avatar
I usually activated crow when flying slower , flaps were activated seperatelly from crow and usually only on landing approach
Old 05-19-2015, 05:36 AM
  #100
w1nd6urfa
w1nd6urfa's Avatar
Makes sense, thanks!
