ESM P-51B vs Model Tech P-51B
I've been looking at these two aircraft for a 30cc engine. I know the Model Tech version is a little smaller but I'm wondering if anyone has seen both and could maybe comment on their impressions of quality, etc between the two. thanks.
RE: ESM P-51B vs Model Tech P-51B
In my honest opinion, a 30cc engine is way to big for either of these airframes.
I was pretty much of a mind the Model Tech was too small; but what do you base your comment on the ESM on, there site says rated for a 26cc gas, pretty much the same thing.
Of the two, the ESM would be the better of the two to use a gas engine. It's a much larger airframe and there are several out there where guys have used gas engines, without having to butcher cowling to bad. If you do a search for the ESM P51B or D model, you'll see some pictures showing a gas engine installations. I will be using a RCV 120 in a ESM P-51.
The model tech p51b is a 90-120 size plane and is only a few inches smaller wingspan than the ESM. As I recall the model tech is about 66 inch wingspan vs 71 inches for the ESM.
You can get spare cowls and canopies from ARFPROS for the ESM. Not sure about the model tech. One of the pilots in my club has the ESM spitfire 71 inch. He used the Syssa 180 gas engine in his. It looks great. The Syssa fits in the spitfire cowl without cutting it much at all - except on the bottom for the cylinder head/spark plug and the muffler tubes. i haven't seen the model tech. Model Tech also has/had a 40 size p51d as well. Ed |
This might be of interest to you I have just finished and test flown my YT (ESM) P51B powered by a JC Aero28.
http://www.ytinternational.co.uk/for...php?f=17&t=399 |
I too am putting a Syssa 180 in the new plane
ORIGINAL: mimoore67 In my honest opinion, a 30cc engine is way to big for either of these airframes. Several people have put 30cc engines in many of the EMS warbirds in this class with excellent results. |
Kinverflyer, I read your YT forum post. Very nice. I love the idea of putting the retract system just in the wing. Could you possibly post a couple of pics here and amplify how you did it. thanks.
Steve |
the modtech one is a little fella, suitable for a 70 size fourstroke, the esm one will be great with any 30cc engine, the engine kinverflyer specs, is a great bit of kit, i favour the dle 30 rear induction, there are build threads of this model, and several others on our YT forum
kinverflyer, is your P-51B version out of production? I can't find it on either VQ or TBM.
martins will be the current version, chek your importers site
http://www.arfpromodelplanes.com/ind...;limitstart=20 |
I would venture a guess and say that the DLE20 cc would be a much better choice in size and power for both airframes considering they would both cowl in perfectly and displace a good amount of power
the 20 would be suitable for 10-15cc models,it would be at the smaller end of the engine range for our birds, the smaller stang would not be suitable for gas conversion
ORIGINAL: ZERO-322 I would venture a guess and say that the DLE20 cc would be a much better choice in size and power for both airframes considering they would both cowl in perfectly and displace a good amount of power The Model Tech P-51B flying weight is 8.75 lbs and is perfect for a 20cc engine. I fly a Great Planes RV-4 which weights 9+lbs w/ a Zenoah G20 and it is great. The ESM P-51B flying weight is 13.5lbs and a 30cc will fly it well. |
Thanks buddy !
the DLE 20 has impressive stats it may seem like a small engine but I think it would fit the bill currently this engine is being flown on a 16 Lbs CMP zero with good results, you be the judge |
1 Attachment(s)
The JC Aero 28 has balanced the plane very nicely, with out the addition of any ballast
seeingas YT have been supplying the mod tech stang, from ages ago, ireally dont think it will suitgas conversion, its an old design, but we still keep getting asked for it, so, it still gets built at the factory, mind you, its supplied with good mech retracts, and a polished ally spinner, it flys well, and even makes a good slope GLIDER!!!
ORIGINAL: splais I've been looking at these two aircraft for a 30cc engine. I know the Model Tech version is a little smaller but I'm wondering if anyone has seen both and could maybe comment on their impressions of quality, etc between the two. thanks. The ESM version is quality film covered (sourced by us, and very good it is too) painted, decalled, then all sealed in with varnish, the mod tech version is film covered, with all decals applied, great, cheap little performer |
ORIGINAL: alanc the modtech one is a little fella, suitable for a 70 size fourstroke, the esm one will be great with any 30cc engine, the engine kinverflyer specs, is a great bit of kit, i favour the dle 30 rear induction, there are build threads of this model, and several others on our YT forum "123551 P-51B Mustang Old Crow 91-120 Size ARF Model Tech ARF's True Scale Series offers serious modelers a plane like no other. This P-51B Mustang's profile is scale and detailed. Inside you'll find laser cut balsa and plywood parts expertly assembled to ensure proper alignment and precision assembly. The cowl is fiberglass, the wing fairings are built-in and the Old Crow scale markings are all applied at the factory. To finish the model, Model Tech Engineers have developed a specialized finishing coat that adheres to regular iron-on covering providing a model that has an even, flat, sealed finish giving the model a painted look like no other ARF available. In the model you'll find optional fixed gear and all the mounting for optional air retracts that can be added later (sold separately). Other Information Functions: Ailerons, Flaps, Rudder, Elevator, Throttle, and Optional Retractable Landing Gear Servos: 6-8 According to power system and retracts chosen. Power: 91 size Compatible with Robart Retractable Landing Gear and Struts Specifications: Wing Span: 1680mm (66.25 inches) Wing Area: 50.6sq dm (785 sq in) Length: 1473mm (58 inches) Flying Weight (varies with equipment): 3950g (8.75lb) Wing Loading: 78g/sq.dm. (25.6 oz/sq ft) Model Tech also has the 40 size which I show below: P-51D Mustang 40 ARF w/Retract w/Monokote The Modeltech P-51D Mustang 40 Size with retracts! This plane is Almost Ready to Fly (ARF) Items Needed: 5 channel radio with 4 standard servo plus 1 retract SX Magnum XLS-46 2-stroke, .70 4-stroke The OP asked about the p51b not the D model. So perhaps you should reconsider your comments? Ed |
Folks, lets not start another thread fight. I got the info I needed and decided that the ESM was the way to go. I always thought it ( Model Tech) was too small for a 30cc plane. Probably fly great on one of the new 20cc engines.
splais - For ESM planes i would suggest you buy from VQ Warbirds. The guy who operates this is active here and seems to be very helpful to people. ARFPROS is now the sole US importer of ESM planes. I think TBM still sells them too.
Ed |
That P-51B looks great http://profile.ak.fbcdn.net/hprofile...249_5513_q.jpg
ORIGINAL: rc34074 splais - For ESM planes i would suggest you buy from VQ Warbirds. The guy who operates this is active here and seems to be very helpful to people. ARFPROS is now the sole US importer of ESM planes. I think TBM still sells them too. Ed |
OOPS!!!! ME BAD mod tech do indeed list a P51B at 66"span, this was part of a range being developed with our help many moons ago, there was quite a few in there, i dont know what happened to them, but we gave up on them, and we are the UK importer, rc34074, please accept my apologies, and thanks for persisting, its been that long since i got the pictures of this new range of aircraft, i had simply erased them from memory, still wont take a 30cc though:D do me a favour you guys, send them a polite email, asking what happened to this range, they would have been very popular if they have already made it to the stores, we havnt seen them, and we where in at the birth!!!</p> |
