Gorilla Glue
What will get gorilla glue off fingers????
RE: Gorilla Glue
Try acetone
RE: Gorilla Glue
Xacto knife, 80grit sandpaper :)
RE: Gorilla Glue
laquer thinner
RE: Gorilla Glue
Time
RE: Gorilla Glue
hellcat, use those medical exam gloves next time. I never touch the stuff without those on my hands. Dan.
RE: Gorilla Glue
ORIGINAL: All Day Dan hellcat, use those medical exam gloves next time. I never touch the stuff without those on my hands. Dan. And with those on your hands, you most certainly won't be touching the stuff. You can get a box of something like 100 gloves at Harbor Freight for almost nothing. |
RE: Gorilla Glue
I have done a fair bit of building over my 25 years in the hobby, but I have never used Gorilla glue.
Always use Sig Aliphatic resin or Titebond, and of course CA and 5min epoxy. So can any of you builders out there tell me what application you use this stuff for, and why. Thanks |
RE: Gorilla Glue
1 Attachment(s)
ME410, I know it doesn't fly, but the Gorilla glue made it much easier. Dan.
RE: Gorilla Glue
Gorilla glue comes off w/ mineral spirts and elbow gresse and I too never used it untill just awhile a go and it's very good for tough app's where you cant really clamp very tight but need it to never come off or need to have a gap filled because of it expanding properties you just have to be carefull not to make a real mess (YOU DON'T NEED MUCH)
Bruce<br type="_moz" /> |
RE: Gorilla Glue
On a balsa sheeted foam core wing where I did not do a good job of sanding the dihedral at the center, I glued the wing halfs together at the correct dihedral and let Gorilla Glue fill the gap. I have also used it to glue an ABS radial engine front and back together where the Gorilla Glue filled the cavity in the engine; it added strength and weight. I have not had good success with using it to glue hardwood to a fiberglass fuselage in a gas plane; the joints eventually vibrated apart.
- Brian |
RE: Gorilla Glue
ORIGINAL: All Day Dan ME410, I know it doesn't fly, but the Gorilla glue made it much easier. Dan. |
RE: Gorilla Glue
1 Attachment(s)
Here's another use. Dan
RE: Gorilla Glue
I find that a butane torch turned up to a blue flame works well to remove the glue. :) Mitch
RE: Gorilla Glue
The best way i have found is not to use that stuff to begin with.
RE: Gorilla Glue
If it is wet use mineral spirits. If it's hard then use sandpaperhttp://www.rcuniverse.com/forum/js/f...sn/biggrin.gifor solvent such as acetone,laquer thinner etc. I find it has it's place for filling in gaps and for gluing foamies back together and for attaching hinge points or nylon hinges it's great. I first coat the hinge joint in vasilene and then apply just a little water to the control surface holes and the trailing edge holes. Next take a tooth pick with a little glue, and I mean a little, and then rub it in the hole insert the hinges and line it up and let it set. In about 1/2 an hr check it again and work the hinges some, don't try to wipe off any glue that foams out yet, when it gets hard you will be able to take a #11 blade and pick the excess right off and your hinges will function just fine, and they will not pull loose, even in a crash. Don't askhttp://www.rcuniverse.com/forum/js/f.../sad_smile.gif
RE: Gorilla Glue
Plus 1 on raptureboy's comments. It's the best glue have found for hingepoints. Most solvents will remove it when still wet.
RE: Gorilla Glue
Interesting stuff, I may give it a try, thanks for the info.
Deatonbt: For any wood to fiberglass I use a glue by PermaPoxy called 5 Min Plastic Weld. The key ingrediant is " Methyl Methacrylate "I think. It's stinky stuff and you don't want it on your skin I would think. But it works great, and you can use it for plastic to wood, plastic to plastic also. Tom |
RE: Gorilla Glue
ORIGINAL: raptureboy If it is wet use mineral spirits. If it's hard then use sandpaper[img][/img] or solvent such as acetone,laquer thinner etc. I find it has it's place for filling in gaps and for gluing foamies back together and for attaching hinge points or nylon hinges it's great. I first coat the hinge joint in vasilene and then apply just a little water to the control surface holes and the trailing edge holes. Next take a tooth pick with a little glue, and I mean a little, and then rub it in the hole insert the hinges and line it up and let it set. In about 1/2 an hr check it again and work the hinges some, don't try to wipe off any glue that foams out yet, when it gets hard you will be able to take a #11 blade and pick the excess right off and your hinges will function just fine, and they will not pull loose, even in a crash. Don't ask[img][/img] |
RE: Gorilla Glue
ORIGINAL: hellcat56 What will get gorilla glue off fingers???? |
RE: Gorilla Glue
Takes no more time and I don't have to hurry up because the epoxy is setting up on me while I'm trying to line up the hinges, and just so you know epoxy will not stick to nylon hinges very long wise guy! Thats why I mix it on plastic container lids and use nylon spatulas,just flex it and it pops right off. http://www.rcuniverse.com/forum/js/f.../thumbs_up.gifIf you've got nothing good to say then keep it to yourselfhttp://www.rcuniverse.com/forum/js/f.../msn/52_52.gifReally why do guys like you have to get in a thread and try to make yourself and your ideas sound sosuperior.
RE: Gorilla Glue
ORIGINAL: raptureboy Takes no more time and I don't have to hurry up because the epoxy is setting up on me while I'm trying to line up the hinges, and just so you know epoxy will not stick to nylon hinges very long wise guy! Thats why I mix it on plastic container lids and use nylon spatulas, just flex it and it pops right off. [img][/img]If you've got nothing good to say then keep it to yourself[img][/img] Really why do guys like you have to get in a thread and try to make yourself and your ideas sound so superior. |
RE: Gorilla Glue
ORIGINAL: raptureboy Takes no more time and I don't have to hurry up because the epoxy is setting up on me while I'm trying to line up the hinges, and just so you know epoxy will not stick to nylon hinges very long wise guy! Thats why I mix it on plastic container lids and use nylon spatulas,just flex it and it pops right off. http://www.rcuniverse.com/forum/js/f.../thumbs_up.gifIf you've got nothing good to say then keep it to yourselfhttp://www.rcuniverse.com/forum/js/f.../msn/52_52.gifReally why do guys like you have to get in a thread and try to make yourself and your ideas sound sosuperior. To the OP, +1 for the gloves. Anytime a job is going to get messy, I opt for the gloves too. But once I get GG on my hands and it turns black from grime, I sand it off the skin. I try hard not to get too much solvent on my bare hands. Skin absorbs solvents |
RE: Gorilla Glue
RE: Gorilla Glue
ORIGINAL: airega1 ORIGINAL: raptureboy If it is wet use mineral spirits. If it's hard then use sandpaper[img][/img]or solvent such as acetone,laquer thinner etc. I find it has it's place for filling in gaps and for gluing foamies back together and for attaching hinge points or nylon hinges it's great. I first coat the hinge joint in vasilene and then apply just a little water to the control surface holes and the trailing edge holes. Next take a tooth pick with a little glue, and I mean a little, and then rub it in the hole insert the hinges and line it up and let it set. In about 1/2 an hr check it again and work the hinges some, don't try to wipe off any glue that foams out yet, when it gets hard you will be able to take a #11 blade and pick the excess right off and your hinges will function just fine, and they will not pull loose, even in a crash. Don't ask[img][/img] I useGG on hinges. Rapture explained it in great detail but it doesn't take long to do at all. |
