P40 ground handling
My Zirolli P40 has terrible ground handling. On take off I steers hard left, not a drift, a turn left.
Gear is straight, both wheels roll free, engine thrust is good Flys like it is on rails , once you get it in the air, landing are straight Engine is a 3w75 turning 6700, Mej 3 blade 22x10. Any suggestion would be helpful. |
RE: P40 ground handling
Never flown a Ziroli P-40 but my Skyshark P-40 will pull hard left on takeoff. My buddy's Yellow P-40 does the same. I'm sure the 3 blade adds to the problem, the old P-factor at work. I find that a very slow throttle up on takeoff until the tail is up with a lot of right rudder is about the only way to stay straight down the runway. Some warbirds do seem to be worse than others.
Carl |
Have you tried more toe-in? I had a Shoestring that was just crazy on the ground till I got enough toe-in, but I remember I also changed prop brands too around the same time. Went from APC to a MAS. Either or both of those changes cured the ground handling craziness. Good luck. Jon
Ran the engine to check tuning. Did notice the engine rpm came up very quick. Engine at full rpm with with transmitter stick at half throttle. Going to try adding expo to slow throttle. Never tried this before. No room to servo or add a longer arm without major rework
1 Attachment(s)
Harley,
My Ziroli P-40 has slight toe-in. I ease up the throttle at take-off with no problems with tracking Add rudder as needed. Happy Flying |
being gradual on the throttle is key, coupled with right rudder, full up elevator on initial portion of roll... Pin that tail down initially, otherwise the tailwheel will not be useful. Slowly release elevator as ground and airspeed build, rudder will be come more authoritative. Use rudder as necessary to maintain heading and continue to relax elevator to neutral position as tail lifts. Speed continues to build on the take off roll. Boom. You're flying. Of course this is an over simplification, and it all comes down to the quirks of your airframe and powerplant. You'll have to keep working at it until you master that specific airframe. SOunds like you've got it into the air in the past. Keep working at it and try to stay ahead of the plane! Anticipate the hard left and compensate before it happens.
I fly an Avenger and the gear are are VERY narrowly space. My Avenger will ground loop (like your P-40 does) in a heartbeat if I don't stay ahead of the plane and anticipate it's "quirks" before they actually happen. Let's see some pictures! Good luck. |
Thanks, as soon as the weather is good ill give it another try. Sounds like easy on the throttle is the key
a few degrees of toe in helps, also a high speed, high torque rudder servo slaved to a gyro works wonders. I had one on my last P40 and had it coupled to the retract channel so that when retracts when up the gyro gain went to zero and vice versa.
It sounds to me like it's acting like a real airplane! P-Factor and slipstream effect working here. All of the advice above is on the money. Slow acceleration, keep the tail down until the rudder becomes effective. My CMP P-40 will do the same thing if I just go to full power at the beginning of the takeoff roll. Dash
<div>"<span style="background-color: rgb(251, 252, 255); font-family: Verdana, Arial; font-size: 12.800000190734863px;"> </span><span style="background-color: rgb(251, 252, 255); font-family: Verdana, Arial; font-size: 12.800000190734863px;">Engine at full rpm with with transmitter stick at half throttle. Going to try adding expo to slow throttle. Never tried this before."</span></div><div>
</div><font size="2">harley, don't know what Tx you have, but my Futaba has a throttle curve feature. If your Tx has it, that feature probably works better than using expo on a throttle.</font><div> </div><div>Brian</div> |
Plus 1 on the throttle curve suggestion. Also, a SLIGHT amount of toe-in helps a lot.
ORIGINAL: harley6133 Ran the engine to check tuning. Did notice the engine rpm came up very quick. Engine at full rpm with with transmitter stick at half throttle. Going to try adding expo to slow throttle. Never tried this before. No room to servo or add a longer arm without major rework Where the pushrod connects to the carb there should be a right angle from the pushrod with the carb arm when the carb is halfway open. Where the pushrod connects to the servo, the servo arm should make a right angle with the pushrod. |
I have 2 ziroli P-40 so can share my 2 cents:
1) If there is cross wind coming at you, make sure you take off in direction of wind blowing toward the right fuselage or you will not stand a chance no matter how good your throttle management is. Right to left if you're facing the wind. 2) P-factor is bigger factor with bigger warbirds. Compensate for that with right and down engine thrust about 3-4 degrees. The P4- sits more noseup than some others so P-factor becomes more prominent until the tail is off the ground. Goal is to get your throttle up enough to get that tail off the ground asap. Tail off the ground will reduce P-factor and also allows rudder to be more effective. Common mistake is to give too much rudder at the start to anticipate that hard pull left, but once tail is in the air need to reduce rudder feed because of the 2 reasons above, or else you find the bird now heading to the right and end up swirling left to right like a drunk on the freeway!!! 3) Do not pull the elevator stick until you got straight tracking and solid airspeed. That 40 lbs P40 will tortoise if you take off too soon even if you got a big 85cc monster up front. I'm not going to tell you how I know :D I do find that take offs with these 40 lbs beasts are trickier than landings sometimes. |
A little right rudder mixed in with the throttle. Just like the real ones..throttle goes up right foot goes in.
The real one was a handful to handle on the ground. So why would you think that the model would be any easier? Lol.
Gyro?
ORIGINAL: kmtranmd 1) If there is cross wind coming at you, make sure you take off in direction of wind blowing toward the right fuselage or you will not stand a chance no matter how good your throttle management is. Right to left if you're facing the wind. |
It would push the tail left and the nose right. Helping offset thrust.
It will push on the large vertical stab in the back "pushing" the tail toward the left and somewhat keeping the typical left pull(nose to the left,tail to the right) in check. That's the outcome when you apply right rudder to compensate.....push the tail to the left.
If the wind is blowing against the tail from the left it will push the tail to the right making the typical left nose pull even worse and harder to compensate with right rudder. |
ORIGINAL: aymodeler ORIGINAL: kmtranmd 1) If there is cross wind coming at you, make sure you take off in direction of wind blowing toward the right fuselage or you will not stand a chance no matter how good your throttle management is. Right to left if you're facing the wind. As soon as the wheels leave the ground the wind pushes the entire plane to the left. |
ORIGINAL: tp777fo A little right rudder mixed in with the throttle. Just like the real ones..throttle goes up right foot goes in. |
ORIGINAL: radfordc ORIGINAL: aymodeler ORIGINAL: kmtranmd 1) If there is cross wind coming at you, make sure you take off in direction of wind blowing toward the right fuselage or you will not stand a chance no matter how good your throttle management is. Right to left if you're facing the wind. As soon as the wheels leave the ground the wind pushes the entire plane to the left. |
Lots of things are obvious once you understand them....like gravity for instance.
ORIGINAL: harley6133 My Zirolli P40 has terrible ground handling. On take off I steers hard left, not a drift, a turn left. Gear is straight, both wheels roll free, engine thrust is good Flys like it is on rails , once you get it in the air, landing are straight Engine is a 3w75 turning 6700, Mej 3 blade 22x10. Any suggestion would be helpful. |
P-40's ground handling, with both r/c models and full size, are tricky due to narrow gear and short coupling.
Use of right rudder and throttle management are key. If your throttle linkage is not set up correctly, it can give you fits on take off. Here's how to set up throttle linkage; Use a Servo arm where the "take off" or "ball link attach" point is about 5/8" from center of shaft. Purpose of that distance is to ensure that you'll be close to needing 100% ATV on both ends of the throttle channel, making the "clicks" of throttle less profound. You don't want big differences per click, and a longer arm will be too much. Shorter arm requires too much ATV diddling, and introduces mechanical expo which may not be in the "correct" direction. On the Carb, use an arm with the ball link take off point at 3/4" from shaft center. This permits more rotation of the arm, and helps solve sensitivity issues mechanically at the carb. Walbro carbs are HORRIFICALLY non linear and overly sensitive... |
