Retracts for Hawker Hurricane
Just got a ESM Hawker Hurricane and from what I have heard I need 95 degree retracts. I assume this is for the gear to suck up completely into wheel wells. What would be the difference between using 95 degree and 90 degree retracts? Thanks!
Bullseye52 :rolleyes: |
If the wing has dihedral, chances are you need 85 degree retracts.
No dihedral in center section, it's flat. Wheels retract to center.
Thanks! Bullseye52 :p |
Based on the drawings and pictures I've seen of the Hurricane, 90 degree retracts should work fine.
Sierra makes what you want, and VQ Warbirds has them in stock: http://www.vqwarbirds.com/product_in...e3a9c3169f29b9
1 Attachment(s)
This image makes the main strut look pretty perpendicular to me.
Don't think I'd spend too much time looking for a set of 95 degree mains if it were my project. http://www.rcuniverse.com/forum/atta...mentid=2143009 |
The Sierras are very nice as they rotate a few degrees during retraction to keep the wheel flat in the well and allow for a gear door that does not have to be at a "wonky" angle. Of course this only works if your gear is set up to retract slightly aft into the scale l location.
The Sierra's work the best for this model.
Cheers, |
