RCU Forums
-   RC Warbirds and Warplanes (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/)
-   -   Phoenix Models A-26 Invader (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/11639738-phoenix-models-26-invader.html)
Steve Collins 06-17-2017 01:10 PM
Just noticed this plane in the Tower ad in the new issue of Model Aviation. Looks pretty good. Not on the Tower website yet though. Looks like a really cool project. 92" wingspan, I believe and ready for either piston engines or electric motors. Anyone know where to get one?
Steve Collins 06-17-2017 06:47 PM
Really. Really, really; right there on page 72. Surely I am not the only one who saw this new model. OBTW, 90.5 inch wingspan.
52larry52 06-21-2017 08:30 AM
Steve, I was just on the Tower Hobbies site and on the "coming soon" list is the A-26 !! Price is $429.99 and is coming in "late July". Looks great, I want one too !
Steve Collins 06-21-2017 12:54 PM
Yep. I think I will have to add one to my overcrowded hangar. Sure wish it was done in aluminum color instead of the gray. Guess I could strip it and make it another color if I really want to.
LDM 06-23-2017 12:31 AM
Yep , I just noticed yesterday and if you google it , you can see a flight video !
I just finished the Phonie Stinson and have the Lizzy in my hanger, for me the quality of Phoniex is outstanding especially when compared with the cost !
I cant wait to get this one , I am going electric powered !
tailskid 06-24-2017 04:07 PM
Video:
uncljoe 07-07-2017 05:08 PM
Looks great electric is the way to go
Semper Fi
Joe
Steve Collins 07-07-2017 05:20 PM
Pre-ordered mine yesterday!
tailskid 07-07-2017 06:33 PM
Two small gassers would be nice:)
uncljoe 07-09-2017 07:37 PM
4 Attachment(s)
Tail skid Started on two of these F7F one electric other two 19 R3Y Hope to have the gear doors issues worked out went fro pneumatic to servo ...
You know just how HOT its been the last few weeks, UG !
Semper Fi
Joe
tailskid 07-09-2017 09:18 PM
I'd LOVE to see that bad boy fly!
LDM 08-05-2017 02:52 PM
The two 32 size epower motors that the Tower Techs suggested are rated at 7 lbs ( best case ) =14 lbs in total.
The plane is listed at 15lbs to 17lbs ?
Anyone have an epower suggestion ?
I would love to use either two 4 cell 4500 packs or jump to two 6 cell 60 size motors
I am not understanding the HV suggestion on the esc considering each motor will have its own set up ?
Also why do you need an 8 channel minimum TX ?
You have alerons =1, Flaps 1, rudder 1, retracts 1, electric motors 1 elevator 1, I am up to 6 channels in total considering all flaps are linked, the alerons are linked , the esc are linked , so what am I doing wrong ?
tailskid 08-05-2017 05:14 PM
Uncle Joe, any updates?
Steve Collins 08-05-2017 07:48 PM
You have ailerons =1, Flaps 1, rudder 1, retracts 1, electric motors 1 elevator 1, I am up to 6 channels in total considering all flaps are linked, the ailerons are linked , the esc are linked , so what am I doing wrong ?
Not sure I would want the ESCs Y'd together on one channel for throttle. Also, it would be advantageous, but not absolutely necessary, to have the nose steering on a separate channel from the rudder allowing ground steering adjustments without messing up the rudder trim.
I will be using a 14 channel receiver and will not be using any wye connectors on mine. Being able to individually adjust everything is really nice.
Steve Collins 08-05-2017 07:54 PM
I had a Hangar 9 B-25 and used Eflite Power .46s. Lots of power to spare. I am considering the same setup for the A26. The Power .46s will be quite happy on the 4 cell 4500s. I flew my B-25 for awhile on 4 cell packs. Later I switched over to 5 cell 5000ma packs which also worked quite well with these motors. If I go with these motors in the A-26, I will definitely use the 5 cell packs again.
LDM 08-05-2017 08:16 PM
Thanks Steve but I only have a 7 channel TX so does that mean I should pass up on this bird ? I have run two esc/ motors off of one y connector with zero issues.
In checking in on the eflight 46 again somewhat confusing info on max weight would come in around 14lbs.
When I do a 55 glow conversion I come in around a 700 or so KV so the 46 makes sense but the factory specs still limit the all up weight when you combine two.
affas 05-15-2018 01:52 PM
Maiden
https://youtu.be/S37Ge2QDNs4
tailskid 05-15-2018 04:04 PM
Congrats on the maiden!
affas 05-24-2018 04:23 AM
Plano78 06-30-2018 03:02 PM
A-26 Beast
https://cimg6.ibsrv.net/gimg/www.rcu...e21b919e5a.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...b589f2da8a.jpg
With a set of DLE-20s for power! Prop clearance IS an issue.
Prekin 07-01-2018 04:18 AM
How does she fly with DLE20? I´m wonderning if 2x RCGF15 would be enough powerful.
affas 07-01-2018 06:43 AM
I am flying with 2 x OS FS62v Plenty of power ....
Plano78 07-01-2018 06:15 PM
With DLE-20s
Much like her namesake she flies fine and as fast as any fighter at the field. She is a tad heavy so you need to FLY HER to the ground and only chop the throttles once you touch down, other wise you drop.
Steve Collins 07-04-2018 01:31 PM
Amen to that! I found that out the hard way when I chopped the throttle too soon. I dropped very quickly. Moderate damage to the retract on one side and several of the wing ribs on both sides at the root.
LDM 09-02-2018 03:46 PM
This is mine on two eflight 60tes & lots of mods
https://cimg9.ibsrv.net/gimg/www.rcu...f53074424.jpeg
https://cimg1.ibsrv.net/gimg/www.rcu...f039c1166.jpeg
https://cimg0.ibsrv.net/gimg/www.rcu...2d1024d0d.jpeg
https://cimg2.ibsrv.net/gimg/www.rcu...7786257c3.jpeg
https://cimg3.ibsrv.net/gimg/www.rcu...ac182f743.jpeg
https://cimg7.ibsrv.net/gimg/www.rcu...9c8977c38.jpeg
https://cimg4.ibsrv.net/gimg/www.rcu...6c19495b0.jpeg
https://cimg5.ibsrv.net/gimg/www.rcu...d81a117d6.jpeg
https://cimg6.ibsrv.net/gimg/www.rcu...ebd1b2bd7.jpeg
https://cimg0.ibsrv.net/gimg/www.rcu...af5ec0931.jpeg
https://cimg8.ibsrv.net/gimg/www.rcu...a3faa662c.jpeg
https://cimg9.ibsrv.net/gimg/www.rcu...31a2bbc9d.jpeg
https://cimg2.ibsrv.net/gimg/www.rcu...e537768d2.jpeg
https://cimg3.ibsrv.net/gimg/www.rcu...abf252efd.jpeg
https://cimg1.ibsrv.net/gimg/www.rcu...63ca2af69.jpeg
https://cimg4.ibsrv.net/gimg/www.rcu...1c6d25fe7.jpeg
https://cimg5.ibsrv.net/gimg/www.rcu...5261d9c95.jpeg
https://cimg7.ibsrv.net/gimg/www.rcu...261d30c52.jpeg
https://cimg6.ibsrv.net/gimg/www.rcu...4d652ca92.jpeg
https://cimg9.ibsrv.net/gimg/www.rcu...0d6f4af32.jpeg
https://cimg8.ibsrv.net/gimg/www.rcu...d25f11f6e.jpeg
https://cimg0.ibsrv.net/gimg/www.rcu...36bcf7227.jpeg
https://cimg1.ibsrv.net/gimg/www.rcu...5f11069b3.jpeg
