need some help finding tri retracts.
building a scratch build, looking for a good set of tri gear for a 10-15lbs.83"wing span,91+engine. (and not just the most expensive)any suggestions?-also,it's going to be for a grass field.
RE: need some help finding tri retracts.
Why not Spring Air's?
www.retracts.com |
You may check out this item on eBay:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3148505674 make sure you check this seller's other stuff.... |
| All times are GMT -8. The time now is 07:42 AM. |
