paint question
Hi All,
I am airbrushing a 1:5 p-47. I am using perfect paint for the od and neutral gray and insignia. It is a beautiful job. I wish to airbrush small details using acylic "nail Paint . What flat clear would I spray over the model when finished. I am also usiong rub on letters for all the stenciling. I have to coat the acrylic it is water based. Tim |
RE: paint question
Tim I don't have an answer or suggestion ,Tim,I have a question what and where do I get the stencil rub on lettering.
RE: paint question
The very best I have ever seen is an automotive clearcoat from PPG. It is called "Flexed and Flat". With most automotive clears you have to add a flettening agent to get the degree of flatness that you want. With "Flexed and Flat", it is already flat. I have used this flat on a large F-86 which was painted with a combination of Testors Model Master paint and Chevron Perfect Paint. This clear gives an extremely nice coat to the paint. I have also used it some repaired sections on a Jet Model Products T-33. This is a sperior product which is fuelproof and WILL NOT YELLOW.
If you decide to use this clear, the trick is to use 1 part clear and 2 parts reducer. It sprays on in light coats and is not prone to runs. |
RE: paint question
stencils are in model railroad section of lhs
| All times are GMT -8. The time now is 10:34 PM. |
