RCU Forums
-   RC Warbirds and Warplanes (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/)
-   -   CG location for a Byron Hellcat?? (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/3205767-cg-location-byron-hellcat.html)
Check6 07-27-2005 02:11 PM
Hello,
I need the CG location for a Byron Hellcat. Thanks in advance.
Fred
Tony Gag Jr. 07-27-2005 04:46 PM
RE: CG location for a Byron Hellcat??
Fred,
How's it going? Hey, drop me an email when you go and fly the Hellcat. I want to come and watch!
Later,
Tony Jr.
Check6 07-27-2005 05:02 PM
Hi Tony,
Will do. If you see your Dad, tell him to come on up and bring Frank.
Fred
popierre 07-28-2005 09:45 PM
the location is easy to find, look on each side of the fuse there should be one small indent on each side of the fuse, about half way down and behind the trailing edge of the wing, drill a small hole where the indent is, hang the plane using the small hole location, don't forget to balance with the gear up.
Pierre
gary9648 07-29-2005 08:25 AM
Very good advice, Also you can call Iron Bay models and they can send you a manual on the kit. good luck with the Helcat. Great flying aircraft
Ta-152 08-02-2005 01:59 PM
Fred, I hope you'll give me a shout when you're going to fly. Jim G
