RCU Forums
-   RC Warbirds and Warplanes (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/)
-   -   cmp planes? (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/4714996-cmp-planes.html)
furnaceman 09-05-2006 08:22 PM
cmp planes?
Just wondering if you guys know who has cmp warbirds in stock? I'm looking for the .40-.50 size.
gnirwin 09-05-2006 08:31 PM
RE: cmp planes?
try Giant Scale Planes.
parrthd 09-05-2006 08:32 PM
RE: cmp planes?
nitroplanes.com or ak models..........
either one should have some in stock
furnaceman 09-05-2006 10:48 PM
RE: cmp planes?
thanks guys! It's a toss up between the f4u and the p40. I tink more twords the p40 though.
Bill
zeno 09-06-2006 02:14 AM
RE: cmp planes?
Both are great looking planes. I have the F4U Corsair (50-sized that is) myself and its a good flier :)
Just be aware of that CMP has the CG's wrong in the manuals!
Moelders 09-06-2006 02:51 AM
RE: cmp planes?
Hi all..
i had only one CMP plane - the Zero.
This plane is famous with it, that it does not fly well. And with the CG ... that is absolutely correct.
When i think about the plane...- i have to say it was a bad decision to buy it...
regards
Tomas
LDM 09-06-2006 04:49 AM
RE: cmp planes?
The bigger CMP planes fly better but every RC plane is the same in one respect and CMP is in this category . CMP did a great job on the "candy dressing on the small planes" as a result mnay builders get lost in the candy .
With that said 1)keep them as light as possible -watch how you use your expozy
2)CG is critical , use a CG formula to ensure its correct
3)INcidence -use a tool to measure the stab , the basic set up on these planes will have the stabs incodence wrong , aslo make sure your wing incidence is also correct .
4)use a wood propeller until you get all of these excatly correct , this way if you nose over , or land hard you can get away with a broken prop and not a bent engine shaft or torn out firewall
Larry S 09-10-2006 10:45 AM
RE: cmp planes?
1 Attachment(s)
I have the CMP 50 Corsair and I love it. The CG on the planes are off a bit and I can't remember exactly what it should be without measuring it again. Only thing I remember is that if you use the plans CG, it will be tail heavy. I had a OS 46 on mine and that is only marginal on a grass field so I went with an old OS 61 I had laying around and what a difference that made. I can now get plenty of ground speed before takeoff without any problem of the plane snapping. You will see in my pictures I completely repainted it and put the machine guns where they are suppose to be.
Phantom pty 09-17-2006 12:55 PM
RE: cmp planes?
I would go for Giant Scale planes (GSP) ...... great quality //..
Tailgunny 04-07-2015 11:47 AM
I have a CMP arf Spitfire still boxed since purchased two years ago- see it in R/C Universe listings-BB
Johnnie Red 04-07-2015 11:30 PM
Most probably the airplanes don't exist any more:o!!! Look at the dates of posting!!!
Johnnie Red 04-07-2015 11:31 PM
9 years zombie thread!!!!
foodstick 04-08-2015 12:21 PM
HK was carrying some CMP stuff a year ago or so..
