RCU Forums
-   RC Warbirds and Warplanes (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/)
-   -   engine question (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/4804733-engine-question.html)
timothy thompson 09-28-2006 06:21 PM
engine question
what would a two stroke equivalent to a saito 80 be?? I HAVE A WING B-25 WITH 2 SAITO 80s im converting to electric. had an engine out and landed safely but dont wish to go through that again. LHS said the eflite 60 outrunner is equivalent to a 60 2 stroke and they told me that eould me the same as a saito 80 fs
timothy thompson 09-28-2006 08:11 PM
RE: engine question
any ideas
TLH101 09-28-2006 10:17 PM
RE: engine question
Most .91 4strokes are comparable to a .61 2 stroke, or slightly more powerful. The .80s are probably just a bit less that a .61 2 stroke. I would say you hobby shop guy is close.
Paul S. 09-28-2006 10:18 PM
RE: engine question
I think you're right in following there lead. That sounds about right on the 2 to 4 stroke power difference. Not sure on an electric equivalent... Good luck
Paul S.
joey_snaproll 09-29-2006 01:02 AM
RE: engine question
Hi before you decide to switch,check out the twin forum about a electronic engine sycronizer.It is a unit that automaticly balances your two engine to run the same.And with a flame out the running engine goes to idle instantly.check it out before you drop the big dollers on electrics.the unit cost around $119.00.
http://www.rcuniverse.com/forum/m_4211050/tm.htm
Joe
timothy thompson 09-29-2006 11:04 AM
RE: engine question
thanks the eflite 60 will fly the h-9 warbird fleet asnd i use 80s on those with no problem. im not getting out of glow just twins!!!!!!!!!!!!!!
i should be ok
