Engine Starting Problems
1 Attachment(s)
Hey Guys,
Im runnin a .46 World Models Mustang with a YS1.10 and my weakass starter wont turn the prop. Also, my *new* battery in my field box will not charge. Ive charged it for 35-ish hours. Any idea's on what i can do, what a good starter for a big engine like the YS110? Thanx, Nik P.S. - When i do get it started *on someone else's setup* the thing is a BEAST!!!!! RRRRRAAAAAWWWWWRRRRR |
RE: Engine Starting Problems
Not sure what charger you are using but the battery should charge right up. What is tha amp hour rating of the battery? What is the charge rate of the charger? Thanks Dave
1 Attachment(s)
ORIGINAL: niklawhorn Any idea's on what i can do, what a good starter for a big engine like the YS110? |
I would use your car batt and see if it is in fact the starter or the little batt that is dead.
