IMP Mig 3
Has anyone built and flown the IMP Mig? What did it weigh? What did you power it with? Thanks Rich
RE: IMP Mig 3
I'm building the new one now. I helped them redesign the plans to something a bit more accurate. They are for experienced builders only as it is a builders kit.
All up I'm expecting it to be around 12-14 lbs. Power will be a Moki 1.8. |
RE: IMP Mig 3
1 Attachment(s)
This is my provect 80.3" ...........beautiful plane
RE: IMP Mig 3
Fokke, I need to you cut me a set of those and a set of the plans for that MiG-3!
Thats a great 1/5th scale. |
RE: IMP Mig 3
Sounds good. I would just build it from plans and cut the kit myself. Do they have any ass, cowl canope for the Mig? Thanks Rich
RE: IMP Mig 3
Hi Evil Merlin, Where did you get the kit? Are the IMP designs available again? Thanks, Dan
RE: IMP Mig 3
OK Evill after one month or little more Ill can send to you one laser cut full kit with epoxi nose and other things .
Right now the laser cutter is overloaded and at earliest can be cut within a month or little longer. Will send you a PM when I can get to it. |
RE: IMP Mig 3
ORIGINAL: DAN REISS Hi Evil Merlin, Where did you get the kit? Are the IMP designs available again? Thanks, Dan I got the MiG-3 kit from ImpScale about 2 years ago give or take. I think they are only doing short kits but you should call/email and ask. |
RE: IMP Mig 3
ORIGINAL: fokke OK Evill after one month or little more Ill can send to you one laser cut full kit with epoxi nose and other things . Right now the laser cutter is overloaded and at earliest can be cut within a month or little longer. Will send you a PM when I can get to it. Fokke, you are the best! Thanks! |
RE: IMP Mig 3
Thank you, Dan.
RE: IMP Mig 3
What kinds of changes were made in these plans? As I have an older set for the Ki-61 I want to build from
RE: IMP Mig 3
???? What does the Ki-61 have to do with the MiG-3?
| All times are GMT -8. The time now is 12:38 PM. |
