RCU Forums
-   RC Warbirds and Warplanes (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/)
-   -   GSP Hellcat engine selection... (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/884243-gsp-hellcat-engine-selection.html)
Zagzoo 06-21-2003 03:32 PM
I am purchasing a GSP Hellcat.. I was trying to decide which motor to put in it. The plane weighs 10lbs, 70" WS... It calls for a 90 2C, or a 120 4C. Can I fly this on the RCV 90? I was seeing if I could get away with it, or should I get the RCV120? I want to use a 3-blade prop. Didnt know if there would be enough ground clearance with the RCV120 with a bigger 3 blade prop?
Any suggestions?
vik 06-21-2003 05:29 PM
use at least rcv 120, and about ground clearance the 3 blade prop has to be smaller then the 2 blade so if itīs ok with 2 blades, it has to by ok with 3 either
Juice 06-21-2003 06:36 PM
RCU had a review on a GSP Corsair a while back. 75.5" WS, 12.4 lbs, and an RCV90. The reviewer was very impresses with the RCV, but as you know, reviews are always on the positive side.
I think RCV engines are perfectly suited for small and mid-size warbirds. I'm currently breaking in a RCV90 for my 1/8 TF Corsair.
As for 3-bladed props, the only one on RCV's list of recommended props is 15.75x13 3-blade... for both the 90 and 120 sizes. I read somewhere that the 120 will give you an few hundred extra RPM over the 90 with the same prop.
Juice
Richard L. 06-21-2003 07:27 PM
Here is the review of the GSP Corsair with the RCV 90SP:
http://www.rcuniverse.com/reviews.ph...ew&reviewid=68
