Engine
Fugi BT 24A Engine question. I traded for this engine it did run but was very hard to start only with the electric starter. I pulled the plug then flipped the engine over with the plug ground to the block no spark. Changed plugs no difference so i put my drill on the shaft
sun it over that should fast enough to produce a spark NO SPARK. I checked the air gap on the coil 7 ths of an inch should be good. Are the magnets on the ,flywheel are they all the same strength? I did remove the flywheel and checked the key OK. Alex |
| All times are GMT -8. The time now is 03:07 PM. |
