WM Zero
can someone give me the cowl dimensions for both the 60 size zero and the 80" wingspan Zero - I'm interested to see if I could inter change the cowl off of my CMP 120 size zero for one of these , the world models one seems to have a cheeked cowl once the notches are cut and the exhaust added I think it would look better scale wise for a A6M5 version the CMP doesn't have this detail on the cowl
any help is greatly appreciated , also any thoughts or an alternative that someone could suggest ? would be a huge help ! thanks guys ! Mike |
RE: WM Zero
I checked all over world models website and no info , sent them an e-mail and all I received was the pricing , which I already knew
RE: WM Zero
I have the GS Zero with an SPE 43cc gasser in it. Only cutout was the bottom of the cowl for the very bottom of the cylinder. It has been a reliable and fun airplane. I would recommend the Tiano retract upgrade.
There is an extensive thread on this plane in RCU. I urge you to do the research. Have fun and good luck! |
RE: WM Zero
Cowl of the 80" one is 9.5" diam to the stepped in parts, for the exhaust, and 8.5" deep, cowl flairs out at 6.875" depth, for the cooling flaps molding, which angles out to10"diam at full cowl depth-hope thats clear?????
RE: WM Zero
Alanc thanks that is a huge help ! don't suppose you have the dimensions for the smaller 60 size zero ?
RE: WM Zero
any advice on which retract servo i should use?? got the hitec hs75-bb and died before the flight...
| All times are GMT -8. The time now is 01:54 PM. |
