Midwest PT 109 kit #901
NY
Started to rebuild and finish a Midwest kit #901 fiberglass hull with
and all wood top and deck
This kit i won on eBay that was started but pilot house was build wrong and made to look like a fishing boat house so cut up and build to right one .The hull was set up for speed boat with 110mm Aluminum Alloy Water Absorbing Steering RC Boat Rudder with 4mm Shaft Axle Strut Mount Bracket and flex drive so remove it all fiberglass hull back to mfg hull .so far it nice 35.5 inch boat which work out to scale 1/28
The smoke tank on back i made from micro bit case and wood and metal part
