Torpedo Boats
These are the motors that I used to replace the motors in my Schnellboote. The previous motors were from All Electronics and were a motor that they listed as coming from the film rewind of a camera. They worked for almost 2 years, but were not very efficient for what I was asking them to do, and required me to use a two bladed prop that bugged the hell out of me because they were so unscale[:'(]
The new motors are stock HPI Micro RS4 motors. They are far more efficient with a lot more torque. They do weigh more, but because of the increase torque and increased efficiency, I was able to reduce the battery packs by one cell to 4 cells. I have also made three bladed props that are 1.5cm in diameter. This configuration now allows me to drive the 21" 1/72nd scale Schnellboot at our club rules speed of about 39k for two to three sorties before having to change out the battery. I am very happy.:D These motors are on Ebay, item number #5909028922. I think that these will work well for any boat at speed up to 30". |
RE: Torpedo Boats
1 Attachment(s)
This is the business end of the S-38.:D
RE: Torpedo Boats
hello all
I am very new to the wonderfull (and very expensive) hobby of RC boats. what i am doing at the moment is converting the revell 1/72 schnellboote. I have added the prop shafts and rudder posts (all three) and have bought a micro RC system am now buying HPI RS4 micro motors. and here is where i hit the hard part what MICRO ESC can i use to run the motors. I would like reverse capability. thank you in advance for any help |
RE: Torpedo Boats
I am using a Duratrak Blast in the Schnellboote. It easially handles the two HPI stock Micro motors. If weight becomes a concern, an LPR will also beable to do that.
RE: Torpedo Boats
IN my country people used tamyia set of pt 17 torpedo boat 1/72 + speed 280 + 6-7 cell accu AAA 750 mah
RE: Torpedo Boats
HI I AM IN THE WORKS FOR A 6' PT BOAT PLANS SAW IT ON E-BAY FINISH FOR A GUY IN FL THERE NO MOTOR ANY ONE HAVE ANY IDEA ON POWER FOR THIS BIG PUPPY IT IS 6' LONG 20" WIDE I TRY TO GET IT ON NEXT TIME RYE
RE: Torpedo Boats
PS I WOULD LIKE TO GO ELECTIC?
RE: Torpedo Boats
there is a dude that built an eight and a 15 footer (pt boat that is ) the 15 footer you can ride in
but , he uses two to three trolling motors not sure how he hooks them up but you can search google under ( rc pt boats ) and you can find it |
RE: Torpedo Boats
With all the talks of the S-100 RC Conversions, I wanted to share my boat with everybody
http://img.photobucket.com/albums/v3...00-2run006.jpg http://img.photobucket.com/albums/v3...00-2run005.jpg http://img.photobucket.com/albums/v3...00-2run002.jpg http://img.photobucket.com/albums/v3...00-2run001.jpg http://img.photobucket.com/albums/v3...irstrun022.jpg http://img.photobucket.com/albums/v3...irstrun021.jpg I love this boat enough to build another one! Mark |
RE: Torpedo Boats
I have more power for that S100 now and I upgraded the battery packs to 8 aaa Nhims..I get about 20 minutes of HARD running in 40 degree water if not colder... so I figure I should get more runtime if the weather was warmer..
The new boat I'm building will either run all 3 shafts or just two...either way I believe this boat will fly :-) Mark |
RE: Torpedo Boats
I am a little late on this subject . :)
8', Higgins 78' PTB, Gun Boat.--all 1/8" ext. ply. -- 41 lb. trolling motor mounted inside the hull and controlled by a Novak Super Rooster Reversing ESC off off a 12 vdc trolling battery. Motor and shafts are connected by a overdriven timing belt drive. Props are 4.5" X 5" P/ 5 blades. SS 5.5' with 5 SS bearings each. 2 SS rudders 2 tone green jungle pant job. 15 USN crew, 6 Aussies, 4 wounded in deck blankets, and 2 dead on deck. 2--50 cals. at bridge. 2-- 37mm cannons amidships, 2-- 50 cals. on bow. 2--50 cals. on stern 2-- Steel tube torpedo tubes and torpedos, followed by newer 2 roll off torpedo racks and torpedos. 120 watt dual channel stereo driving 8 --large car speakers that have a custom speed and volume linkage to increase together and set for slight off synchronized that almost meet at top speed. That alone stands the hair up on my body, on a head on attack run, at top speed. The boat almost yanked me, 190#. off the dock when I slammed the throttle wide open. I did 1/2 undress to remove the splinters. A 21# trolling motor was border line. the 41# is perfect. She is on plane in 30' to 50'. " They were expendable " still gets my juices going. I joined PTB's Inc. to get a original PTB sound track and support the groups efforts. I have a 80' ASR boat framed up for the 21# trolling motor but my interests have changed to volunteering my time to free boats for kids in schools. My Mother said I could come back from playing in the desert with mud on my shoes. :D |
RE: Torpedo Boats
It's never too late for a project!!!
Tonight I tried out my new props..man can this boat move with less power now.. Classic Warships sells the problems for like $4.00 for the set of 3 this makes a difference in the water! Mark |
RE: Torpedo Boats
RYE. Are you still with us ?
PM me and I will help you with a tough as nails motor and reverseable ESC for the 6' footer. Rich |
RE: Torpedo Boats
Hey, I am building a 1/20 scale ELCO 80' PT boat. I want to power it with 3 motors and have this idea of using 3 ESC's spliced together out of the receiver. Has anyone tried this?
Thanks, Wade |
RE: Torpedo Boats
will it fry the wires..........
RE: Torpedo Boats
Not sure, I'll let everyone know next week, I shoulde have them all set up by then.
RE: Torpedo Boats
ok good luck might not what setup are you running
RE: Torpedo Boats
OK, got the speed controllers in and setup and all seems to be running well. I am running 3 Proboat "Riptide" ESC's that are Y connected into one channel. Then each speed controller will have one or two 6 cell nicd battery packs.
RE: Torpedo Boats
