RCU Forums
-   RCUniverse.com FAQ (https://www.rcuniverse.com/forum/rcuniverse-com-faq-73/)
-   -   32 Bit DYS Basecom 3 axis Gimbal Controller (https://www.rcuniverse.com/forum/rcuniverse-com-faq-73/11610818-32-bit-dys-basecom-3-axis-gimbal-controller.html)
airoJaak 12-20-2014 07:54 PM
2 Attachment(s)
Please...I know there are 100's of sites, etc for this thing but I need some basic help. I have looked at the wiring diagrams, etc.
Question 1: Can I use normal 3 wire servo connections to ROLL, PITCH and YAW from TX to controller? I realize that doing this is actually putting power to the board.
Question 2: If I do this (all three servo connectors), do I still need a separate battery connected to the board or will that fry everything?
Question 3: The package came with two IMU's and one wire. Do I plug the hardwired IMU into the second (frame) IMU then run the second wire from the (frame) IMU to the IMU slot on the controller?
Question 4: I can't tell which of the 3 wires coming off the gimbal motors is the negative and which way to plug them into the controller as that is not marked either.
If anybody can help with this I would GREATLY appreciate it!!!!
Pics attached.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
