sp120
sp120
I have a VQ P-61 waiting for some engines. I've been considering the 120 sp. I'm going to need 2 of course. First, do you think this engine will be reliable enough for a twin? And second, any chance I can get a discount on the purchase of 2?
Thanks.
Thanks.
RE: sp120
Hi
Thanks for your interest in RCV engines. The RCV120SP should be able to power your VQ p-61. You will need to ensure that you have enough clearance for the larger propellers though. If you use 2-bladed props you will need 18x12 or 20x12. If it has enough power and you want to use 3-bladed propellers, the smallest size we would recommend is 15.75x13.
With regard to discounts, I am sure that one of the RCV dealers would give you a discount if you purchased 2. If you email me with your address I can identify one to contact - [email protected]
Best regards
Laurenne
Best regards
Laurenne
RE: sp120
Thanks so much! I am planning to try to use 4 bladed props like the full scale planes. I will check on the clearance, otherwise, do you think the 91's will work with this plane?
WI
RE: sp120
donddsms
I thought that would be quite the setup myself. After seeing that black beauty, I just knew I needed to put that little jem on my short list. The RCV pinecone enging is just screaming out for that airplane.
RE: sp120
If not the 91CD should also be fine for this model. It is at the lower end of the power the kit recommends, but I am sure it will be up to the job.
Best regards
Laurenne
Best regards
Laurenne
