RCV Engines Support Ask RCV Technical Support all your RCV engine questions!
Engine for a 60 TF Corsaire.
Old 02-26-2006, 10:24 PM
madolive3
Default Engine for a 60 TF Corsaire.
I'm looking at engines for my plane. speed and climb rate are inportant to me. Would a 120 be too much for this bird?
Old 02-28-2006, 10:44 AM
RCV Engines
Default RE: Engine for a 60 TF Corsaire.
Hi
Looking at the specs of this model, I would say you would be better off going for a .90 size 4-stroke. Either our RCV91CD or RCV90SP would be perfect.
In terms of speed and rate climb, both should have ample power to pull a 9lb model around the sky. If you are looking to do aerobatics then I would recommend the CD series as has higher rpm at the prop. If you are looking for scale, the RCV90SP would be perfect.
I hope this helps
Best regards
Laurenne
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
