RCV Engines Support Ask RCV Technical Support all your RCV engine questions!
RCV.90SP & 3 blade prop
Old 10-05-2006, 11:15 AM
Allison V-12
Default RCV.90SP & 3 blade prop
Hey guys, I am starting a T/F P-51B .60 and plan on using a .90SP to push a 15-7-13 or
16-7-13 Zinger prop for scale apearance. What do you recomend? thanks, V-12
Old 10-09-2006, 05:24 AM
RCV Engines
Default RE: RCV.90SP & 3 blade prop
Hi
The smallest prop you would want to use on the RCV90SP is a 16x16.
Otherwise you can pull a 17x13 or 18x12 2-bladed prop.
If you want to look at 3 or 4-bladed props, you would look at a 15x13.5 3B or 15.5x12 4B
I hope this helps
Best regards
Laurenne
Old 10-15-2006, 06:00 AM
Allison V-12
Thanks for the answer, I am really looking at a 3 blade prop for scale, I have been getting conflicting info from different sources, and I want to run the biggest prop I can and still get scale speed. You recoment a 15x13.5 3B how will a 17x12, 17x10 or a 18x10 do?? not enoughf pitch ar just too big for a .90 SP? How about a 120SP to push them?? Thanks a bunch..V-12
Old 10-16-2006, 05:53 AM
RCV Engines
Hi
A 17x12 might be okay if you can find one. Or a 17x13 would be even better. It is possible that a 10 pitch wouldn't be enough.
I hope this helps
Best regards
Laurenne
Old 10-18-2006, 04:55 AM
Allison V-12
Laurenne: thanks a bunch, that was exactly what I was looking for. V-12
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
