RCV Engines Support Ask RCV Technical Support all your RCV engine questions!
RCV 91-CD compression?
Old 07-05-2007, 04:51 AM
justy_123
justy_123's Avatar
Default RCV 91-CD compression?
Hi RCV Engines.
I just bought the 91cd engine last week and so far the engine has been run-in for 1.5 hours on a test stand. The engine runs really nice and sounds great but I have a question.
This is my first 4 stroke and I am just wondering about it's compression. For some reason I am able to turn the prop quite easily over the compression stroke. I can feel slight compression but its pretty weak compared to my 2 strokes where its an effort to move the prop over compression. I have tried with the Carburettor closed and also open but the compression still seems to be low.
It's weird because after the prop is rotated 5 or so times the next compression stroke is felt quite good.
Is this lowish compression normal for a 4 stroke and to also be inconsistent?
Please let me know because I am slightly concerned.
Justin.
Old 07-05-2007, 10:02 AM
RCV Engines
Default RE: RCV 91-CD compression?
Hi Justin
Thank you for your query.
I have spoken to our Chief Technican who has advised me that our 91CD compression tends to be lower that a poppet valve 4 stroke engine, due to the rotating cylinder and that you should not be concerned.
I hope this information is helpful.
Thank you and kind regards
Stephanie
