Carburator
Carburator
Hello, dear RCV users, I have an RCV120 SP which performs very fine and reliable. However, there is one funny thing: Full RPMs are not achieved when the throttle is fully open, but only when the caburator is 1-2mm before max. open. On every needle setting, from very rich to lean there is a significant RPM drop as soon as the barrel rotates to fully open. There is light axial play when pushing the barrel on the throttle arm, something I do not consider unusual.
Does anybody have some explanations? []
Thank you
Andi
Thank you
Andi
ON, CANADA
RE: Carburator
Andi,
What you describe is the same behaviour I have on my two RCV engines (60SP and 90SP). A long time ago, I remember reading somewhere on RCU something along the lines of...
"Fully open barrel doesn't mean maximum RPM. On your TX throttle channel, adjust the high end-point for maximum RPM, which will be a little short of fully open".
I've been doing this for my RCV powered airplanes ever since and haven't thought twice about it.
It's not an explanation, but I hope this helps.
Juice
Juice
RE: Carburator
Hi Juice,
thank you, if thats common on an RCV I am happy with that. Was thinking of bent needle valves, dirty intakes and such stuff. [)]
So the solution is a matter of seconds.
Regards
Andi
Regards
Andi
