RCV Engines Support Ask RCV Technical Support all your RCV engine questions!
RCV .91 - this could happen to you!
Old 05-17-2010, 05:55 PM
RWeston
RWeston's Avatar
Default RCV .91 - this could happen to you!
My RCV .91 engine has been somewhat negleted for a couple of years, now, but it's spring and I figured "what-the-heck" let's start 'er up!
Almost got it running the first day - no luck. But the next morning I couldn't turn the prop more than 5 degrees either way! It felt like a rock was stuck in the cylinder and was stopping the piston.
Disassembled the engine and realized I still couldn't rotate the cylinder, in its housing, any more than 3 "teeth" either way.
I soaked the cylinder and its housing over night in alcohol and it finally loosened up and with a little more soaking and rotating the cylinder now rotates freely.
Apparently a piece of hard "varnish" got lodged in the bearing-chase because it took a lot of soaking to soften it up.
I guess the moral is - "clean 'em real good before you put 'em on the shelf."
