RCU Forums
-   RCV Engines Support (https://www.rcuniverse.com/forum/rcv-engines-support-145/)
-   -   RUNNING TEMPERATURE (https://www.rcuniverse.com/forum/rcv-engines-support-145/4624797-running-temperature.html)
YORAM1955 08-15-2006 05:27 AM
RUNNING TEMPERATURE
Hello , I am running in my 120 SP, what is the correct temperature for an uncowled engine running at full power, what is the safe range?
Yoram
RCV Engines 08-16-2006 08:01 AM
RE: RUNNING TEMPERATURE
Hi Yoram
The RCV engine runs around 185 - 200 degrees at the exhaust. There is no correct temperature as this will depend on the environment etc. The engine has good thermal characteristics (with no hot or cold spots) so as long as you don't notice a significant power drop due to heat, then it will be running in the safe range.
I hope this helps
Best regards
Laurenne
YORAM1955 08-16-2006 08:27 AM
Thanks, I assume you are talking about degrees Cesius?
Yoram
RCV Engines 08-16-2006 08:47 AM
Sorry about that. Yes I am talking about degrees celsius
Best regards
Laurenne
