RCV 91CD oops during run-in
I fired up my RCV-91CD today. It ran a bit rough, and I noticed some oil coming out the front bearing.... Then I realized I left the black cap on the crank case nipple. Ugh. The engine runs better after the cap is removed and there is less oil/fuel around the front bearing. Is it possible I damaged anything???
RE: RCV 91CD oops during run-in
Hi Dave
Oops, if all else fails read the instructions ;) Don't worry, you should not have damaged the engine by leaving the cap on. I am pleased your engine is running better now. Best regards Laurenne |
Thanks! That's a relief.
One more question, I know that the instructions recommend Omega 10%, but carrying a 2nd fuel jug just for the RCV is not optimal. I use 15% S&J fuel (castor oil lubricant)... would this be acceptable? |
Hi Dave
I can't find any listing for S&J fuel, so cannot give you a comprehensive answer. Between 5 - 15% nitro is fine, so that is not a problem. You mention it is a castor oil lubricant - do you know what %. This could be a problem as although we recommend some castor it is important not to use more than 6%. Anymore than this will cause the very rough running. In fact on the CD series, if you can't use one of our recommended fuels, we prefer you use a high quality synthetic oil. I hope this helps Regards Laurenne |
Hi Laurenne,
That's very good to know. Luckily, my club stocks 15% in both Castor and Synthetic flavors. I'll most likely switch to the synthetic! Thanks again! - Dave |
| All times are GMT -8. The time now is 02:53 PM. |
