Which engine should i use?
Hello,
I have the new Top Flite Cessna 310 which calls for 2 OS 46ax's. In actual test, these small engines have shown to be more than enough power and fly it well at 1/2 throttle. I was thinking of using either 2 58cd's w/11x8 prop or 2 60sp's w/14 or 15" 3-blade prop. Which would you suggest and what props? Thanks, Rob |
RE: Which engine should i use?
Hello Rob
We would suggest that you use 2x58 CD as we have had good feedback from this application. 11x7 would be a better choice of prop. Regards Ray |
Thank you!
ORIGINAL: RCV Engines Hello Rob We would suggest that you use 2x58 CD as we have had good feedback from this application. 11x7 would be a better choice of prop. Regards Ray |
| All times are GMT -8. The time now is 08:29 PM. |
